Saltar al contenido principal
MacBook Unibody Model A1342 Hard Drive Replacement
Sólo Prerrequisito
Esta guía solo debería usarse como prerrequisito para otras guías. Por tanto, estará incompleta.
Qué necesitas
  1. MacBook Unibody Model A1342 Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 1
    • Remove two 11 mm Phillips screws securing the hard drive bracket to the upper case.
    • These screws are captive in the hard drive bracket.
  2. MacBook Unibody Model A1342 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Lift the retaining bracket out of the upper case.
    • When putting the bracket back after replacing the drive, it is easy to put in backwards. If it doesn't seat smoothly, then reverse it and try again.
  3. MacBook Unibody Model A1342 Hard Drive Replacement: paso 3, imagen 1 de 3 MacBook Unibody Model A1342 Hard Drive Replacement: paso 3, imagen 2 de 3 MacBook Unibody Model A1342 Hard Drive Replacement: paso 3, imagen 3 de 3
    • Lift the hard drive by its pull tab and pull it away from the upper case, minding the cable still attaching it to the logic board.
    • In some revisions of the MacBook A1342, the hard drive bracket may include two rubber brackets (as highlighted in the second picture.) The correct orientation of the rubber brackets is shown in the third picture.
  4. MacBook Unibody Model A1342 Hard Drive Replacement: paso 4, imagen 1 de 2 MacBook Unibody Model A1342 Hard Drive Replacement: paso 4, imagen 2 de 2
    • Remove the hard drive cable by pulling its connector straight away from the hard drive.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 995
