Saltar al contenido principal
MacBook Unibody Model A1342 Disassembly
Qué necesitas
  1. MacBook Unibody Model A1342 Disassembly, Lower Case: paso 1, imagen 1 de 2 MacBook Unibody Model A1342 Disassembly, Lower Case: paso 1, imagen 2 de 2
    • Using a PH00 bit, remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
  2. MacBook Unibody Model A1342 Disassembly, Identify: paso 2, imagen 1 de 1
    • Identify the parts we need to remove. Start with unplugging the battery (circled in red), followed by removing the RAM sticks (circled in orange), and lastly removing the hard drive (circled in green).
  3. MacBook Unibody Model A1342 Disassembly, Unplug Battery: paso 3, imagen 1 de 3 MacBook Unibody Model A1342 Disassembly, Unplug Battery: paso 3, imagen 2 de 3 MacBook Unibody Model A1342 Disassembly, Unplug Battery: paso 3, imagen 3 de 3
    • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
  4. MacBook Unibody Model A1342 Disassembly, Remove RAM: paso 4, imagen 1 de 1
    • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
  5. MacBook Unibody Model A1342 Disassembly, RAM cont.: paso 5, imagen 1 de 2 MacBook Unibody Model A1342 Disassembly, RAM cont.: paso 5, imagen 2 de 2
    • After the RAM chip has popped up, pull it straight out of its socket.
    • BE SURE TO HANDLE THE RAM STICK BY THE EDGES. DO NOT TOUCH THE CIRCUITRY.
  6. MacBook Unibody Model A1342 Disassembly, Second RAM Stick: paso 6, imagen 1 de 3 MacBook Unibody Model A1342 Disassembly, Second RAM Stick: paso 6, imagen 2 de 3 MacBook Unibody Model A1342 Disassembly, Second RAM Stick: paso 6, imagen 3 de 3
    • Repeat steps 4-5 to remove the second RAM stick.
  7. MacBook Unibody Model A1342 Disassembly, Hard Drive: paso 7, imagen 1 de 1
    • Identify Hard Drive.
  8. MacBook Unibody Model A1342 Disassembly, Hard Drive cont.: paso 8, imagen 1 de 3 MacBook Unibody Model A1342 Disassembly, Hard Drive cont.: paso 8, imagen 2 de 3 MacBook Unibody Model A1342 Disassembly, Hard Drive cont.: paso 8, imagen 3 de 3
    • Using a PH00 bit, remove two 11 mm Phillips screws securing the hard drive bracket to the upper case.
    • Lift the retaining bracket out of the upper case.
  9. MacBook Unibody Model A1342 Disassembly, Hard Drive cont.: paso 9, imagen 1 de 1
    • Using PH00 bit, unscrew the 4mm Phillips screw holding down the ribbon attaching the HDD to the motherboard.
  10. MacBook Unibody Model A1342 Disassembly, Hard Drive cont.: paso 10, imagen 1 de 2 MacBook Unibody Model A1342 Disassembly, Hard Drive cont.: paso 10, imagen 2 de 2
    • Using the flat end of a spudger, detach the ribbon from the motherboard.
  11. MacBook Unibody Model A1342 Disassembly, Removed Hard Drive: paso 11, imagen 1 de 3 MacBook Unibody Model A1342 Disassembly, Removed Hard Drive: paso 11, imagen 2 de 3 MacBook Unibody Model A1342 Disassembly, Removed Hard Drive: paso 11, imagen 3 de 3
    • Congrats, you have removed the hard drive!
  12. MacBook Unibody Model A1342 Disassembly, SATA: paso 12, imagen 1 de 3 MacBook Unibody Model A1342 Disassembly, SATA: paso 12, imagen 2 de 3 MacBook Unibody Model A1342 Disassembly, SATA: paso 12, imagen 3 de 3
    • Remove the SATA cable from the hard drive by gently pulling the connector away from the body of the hard drive.
  13. MacBook Unibody Model A1342 Disassembly, Nice Job!: paso 13, imagen 1 de 1
    • To replace all the removed parts, do the aforementioned steps in reverse order.
Conclusión
Una persona más ha completado esta guía.
Bob McBoberface
Miembro Desde 12/09/16
161 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 1,315
