Saltar al contenido principal
MacBook Pro 17" Unibody Hard Drive Bracket Replacement
Qué necesitas
  1. MacBook Pro 17" Unibody Hard Drive Bracket Replacement, Lower Case: paso 1, imagen 1 de 1
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 17" Unibody Hard Drive Bracket Replacement: paso 2, imagen 1 de 2 MacBook Pro 17" Unibody Hard Drive Bracket Replacement: paso 2, imagen 2 de 2
    • Wedge your fingers between the lower case and the vent, and lift upward to release the two clips holding the lower case to the upper case.
    • During reassembly, carefully align the lower case and then press it firmly until both clips engage.
    • Remove the lower case.
  3. MacBook Pro 17" Unibody Hard Drive Bracket Replacement, Battery: paso 3, imagen 1 de 3 MacBook Pro 17" Unibody Hard Drive Bracket Replacement, Battery: paso 3, imagen 2 de 3 MacBook Pro 17" Unibody Hard Drive Bracket Replacement, Battery: paso 3, imagen 3 de 3
    • Whenever working near the logic board, it is always wise to first disconnect the battery to avoid short circuits.
    • If present, grab the plastic tab attached to the battery connector and pull it toward the front edge of the device. For Late-2011 models the battery connector will not have a tab and is simply a plug that inserts straight down into the motherboard--to remove pry the plug straight up.
    • If the plastic tab is missing, use a spudger to pry the connector up from its socket.
    • Pull the tab parallel to the face of the logic board.
  4. MacBook Pro 17" Unibody Hard Drive Bracket Replacement, Hard Drive: paso 4, imagen 1 de 1
    • Remove the two Phillips screws securing the hard drive bracket to the upper case.
    • These screws are captive to the hard drive bracket.
  5. MacBook Pro 17" Unibody Hard Drive Bracket Replacement: paso 5, imagen 1 de 1
    • Remove the hard drive bracket from the upper case.
  6. MacBook Pro 17" Unibody Hard Drive Bracket Replacement: paso 6, imagen 1 de 1
    • Use the hard drive's pull tab to lift it out of the upper case.
    • Don't try to completely remove the hard drive just yet! Its cable is still connected.
  7. MacBook Pro 17" Unibody Hard Drive Bracket Replacement: paso 7, imagen 1 de 2 MacBook Pro 17" Unibody Hard Drive Bracket Replacement: paso 7, imagen 2 de 2
    • Pull the hard drive connector away from the body of the hard drive.
    • Remove the hard drive from your MacBook Pro.
  8. MacBook Pro 17" Unibody Hard Drive Bracket Replacement, Hard Drive Bracket: paso 8, imagen 1 de 1
    • Remove the two 5 mm Phillips #00 screws securing the hard drive bracket to the upper case.
  9. MacBook Pro 17" Unibody Hard Drive Bracket Replacement: paso 9, imagen 1 de 3 MacBook Pro 17" Unibody Hard Drive Bracket Replacement: paso 9, imagen 2 de 3 MacBook Pro 17" Unibody Hard Drive Bracket Replacement: paso 9, imagen 3 de 3
    • Tilt the outer hard drive bracket up toward the logic board and remove it from the rear case.
Conclusión
10 personas más completaron esta guía.
Sam Goldheart
Miembro Desde 10/18/12
471,732 Reputación
538 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
Miembros de 118
19,537 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 4,740
