Introducción
Use this guide to replace a broken AirPort Extreme card.
Qué necesitas
Use your fingers to push both battery release tabs away from the battery and lift the battery out of the computer.
Remove the four identical Phillips 3.4 mm screws from the memory door. These screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
Remove the three Phillips screws in the battery compartment near the latch. Apple was nice enough to tilt these screws at a slight angle to make them easier to remove. On the A1261 these screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
Disconnect the two antenna cables attached to the AirPort Extreme card.
Turn the Airport Extreme card over and remove the single silver Phillips screw from the top right corner of the Airport card.
32 personas más completaron esta guía.
2 comentarios
This was SO helpful. Sad to say that for me it does not last. I have had to do this 3 times because within 8+ years since I bought the 1261 new, the cards fail by turning off. The times between card shut off get shorter and shorter until I have to do it again. Maybe the cards though new are not that good (though cheap) or maybe its something else. I continue to want to keep it running because with the latest OS it works so well. Now with 1TB SSD and the screen it came with, why get a new one when screens are smaller? So happy with this website!
Jim in Chicago
