Qué necesitas
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm (14.1 mm) Phillips screws.
Seven 3 mm Phillips screws.
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Pull the camera cable connector straight out of its socket on the logic board.
Remove the 8.6 mm Phillips screw securing the antenna/camera cable retainer to the upper case.
Remove the antenna/camera cable retainer from the upper case.
Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
Rotate the display slightly away from the upper case.
Lift the display up and away from the upper case, minding any brackets or cables that may get caught.
Starting on the right side of the display, slide the antenna's plastic cover approximately 1/4" to the right.
Then, lift up the right edge of the plastic cover just enough to separate it from the display.
Continue lifting the cover along its length, until the entire cover is separated.
Remove the plastic cover and retain for reassembly.
Optional: Place a cover on top of your display, just in case your screwdriver slips.
Remove the two #000 Phillips screws on the far-right (see detail photo).
Remove the somewhat-hidden #000 Phillips screw on the far-left of the display (see detail photo).
Remove the six #000 Phillips screws in the middle of the antenna board.
Make sure to re-wrap the Antenna/iSight cables back with some tape. If your replacement part did not include any, reuse the one you took off. My replacement part came with tape, but I still put a bit of Kapton tape around the black tape to completely close the fold.
The new antenna hopefully came with the small grounding straps that go around the cables, and get screwed in on the far-right of the display. If they didn't, you'll need to remove them from the old antenna.
Insert the replacement board starting with the far-left side. Once inserted, the board should sit loosely in the grooves of the display.
When installing the new antenna, first screw in one of the six center screws -- that will help align the far-left screw over its hole.
2 personas más completaron esta guía.
