Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
MacBook Pro 15" Unibody Mid 2009 RAM Replacement
Qué necesitas
  1. MacBook Pro 15" Unibody Mid 2009 RAM Replacement, Lower Case: paso 1, imagen 1 de 1
    • Seven 3 mm Phillips screws.
    Pregunta a FixBot
    Agregar Comentario
  2. MacBook Pro 15" Unibody Mid 2009 RAM Replacement: paso 2, imagen 1 de 2 MacBook Pro 15" Unibody Mid 2009 RAM Replacement: paso 2, imagen 2 de 2
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
    Pregunta a FixBot
    Agregar Comentario
  3. MacBook Pro 15" Unibody Mid 2009 RAM Replacement, RAM: paso 3, imagen 1 de 2 MacBook Pro 15" Unibody Mid 2009 RAM Replacement, RAM: paso 3, imagen 2 de 2
    • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • After the RAM chip has popped up, pull it straight out of its socket.
    • Repeat this process if a second RAM chip is installed.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
161 personas más completaron esta guía.
5Guía Comentarios
I bought and installed 4GB x2 RAM for my Mid 2009 15 inch MacBook Pro and it was easy and is working great. Before this I had 4GB and it was being maxed out. It was very easy. I did purchase the required tools which made it simple. I also swapped the battery at the same time. I am writing this from the same computer and it is working well. Good luck!
1tom2go - Contestar Compartir
I had no trouble installing the 4 GB RAM I bought for my Mid 2009 15 Inch MacBook Pro. The mistake I made though was not realising that my machine has two RAM slots. I only bought one chip! So now I have to buy another one.
If you read this before you buy some RAM, make sure you check how many slots your computer has!
Also, I must say the customer support from ifixit is great. I messaged them about this and some other issues I was having and I got a detailed response from them within a couple of days. Thanks guys!
oliverbarrand - Contestar Compartir
Thanks! You saved my life.
saltyhf - Contestar Compartir
I replaced my original 2x 2gb ram with 2x 4gb RAM following your instructions. However, upon boot up, it’s only showing 1 of the 2 4gb chips. Any tips on how to get both seated correctly?
Matthew Longo - Contestar Compartir
Never mind. I was able to pop the second chip back out and get it seated properly.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 20
Ultimos 30 días: 70
Todo El Tiempo: 63,156
