Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement
Qué necesitas
  1. MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement, Lower Case: paso 1, imagen 1 de 1
    • Seven 3 mm Phillips screws.
    Pregunta a FixBot
    Agregar Comentario
  2. MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 2, imagen 1 de 2 MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 2, imagen 2 de 2
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
    Pregunta a FixBot
    Agregar Comentario
  3. MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement, Battery: paso 3, imagen 1 de 1
    Herramienta utilizada en este paso:
    P6 Pentalobe Screwdriver 2009 15" MacBook Pro Battery
    $5.49
    • Remove the two 5-Point Pentalobe screws along the top edge of the battery.
    • You do not necessarily have to follow steps 3-6 to remove the battery in order to replace the hard drive. However it is recommended to remove all power sources from electronics before working on them.
    Pregunta a FixBot
    Agregar Comentario
  4. MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 4, imagen 1 de 1
    • Use the tip of a spudger to bend back the finger of the "Warning: Do not remove the battery" sticker while you remove third five-point Pentalobe screw hidden underneath.
    Pregunta a FixBot
    Agregar Comentario
  5. MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 5, imagen 1 de 2 MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 5, imagen 2 de 2
    • Lift the battery by its plastic pull tab and slide it away from the long edge of the upper case.
    • Do not try to completely remove the battery just yet.
    Pregunta a FixBot
    Agregar Comentario
  6. MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 6, imagen 1 de 1
    • Tilt the battery back enough to access the battery cable connector.
    • Pull the battery cable connector away from its socket on the logic board and remove the battery from the upper case.
    • If you're installing a new battery, you should calibrate it after installation.
    Pregunta a FixBot
    Agregar Comentario
  7. MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement, Display: paso 7, imagen 1 de 1
    • Apple sticks a small strip of clear plastic with adhesive applied to one side of the logic board behind the camera cable connector to keep it in its socket. When moving it out of the way, be sure not to break any surface-mount components off the logic board.
    • Use the tip of a spudger to rotate the plastic retainer away from the camera cable connector.
    Pregunta a FixBot
    Agregar Comentario
  8. MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 8, imagen 1 de 2 MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 8, imagen 2 de 2
    • Pull the camera cable away from its socket on the logic board.
    • Pull the connector parallel to the face of the logic board, not straight up.
    Pregunta a FixBot
    Agregar Comentario
  9. MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 9, imagen 1 de 1
    • Peel the camera cable off the adhesive securing it to the body of the optical drive.
    Pregunta a FixBot
    Agregar Comentario
  10. MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 10, imagen 1 de 2 MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 10, imagen 2 de 2
    • This step is only required if you have an anti-glare display. If you have a glossy display, skip to step 12.
    • Disconnect the Bluetooth cable by pulling the male end straight away from its socket.
    • Use the flat end of a spudger to pry the Bluetooth antenna cable up from its socket on the board.
    Pregunta a FixBot
    Agregar Comentario
  11. MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 11, imagen 1 de 2 MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 11, imagen 2 de 2
    • Remove the two 8 mm Phillips screws securing the Bluetooth/camera cable retainer to the upper case.
    • One of the screws may remain captive in the Bluetooth/camera cable ground loop. If replacing the display, be sure to transfer this screw to the new unit.
    • Lift the Bluetooth board/cable retainer assembly out of the upper case.
    Pregunta a FixBot
    Agregar Comentario
  12. MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 12, imagen 1 de 2 MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 12, imagen 2 de 2
    • This step is only for glossy display machines. If you have an anti-glare display, skip this step.
    • Remove the two 8 mm Phillips screws securing the camera cable retainer to the upper case.
    • One of the screws may remain captive in the camera cable ground loop. If replacing the display, be sure to transfer this screw to the new unit.
    • Lift the camera cable retainer out of the upper case.
    Pregunta a FixBot
    Agregar Comentario
  13. MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 13, imagen 1 de 2 MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 13, imagen 2 de 2
    • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
    Pregunta a FixBot
    Agregar Comentario
  14. MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 14, imagen 1 de 2 MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 14, imagen 2 de 2
    • Remove the single 7 mm Phillips screw securing the display data cable retainer to the upper case.
    • This screw may remain captive in the display data cable ground loop. If replacing the display, be sure to transfer this screw to the new unit.
    • Remove the display data cable retainer from the upper case.
    Pregunta a FixBot
    Agregar Comentario
  15. MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 15, imagen 1 de 1
    • Be sure the display data cable lock is rotated toward the DC-In board before proceeding.
    • Pull the display data cable connector straight away from its socket.
    • Make sure to pull the connector parallel to the face of the logic board, not straight up from its socket.
    Pregunta a FixBot
    Agregar Comentario
  16. MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 16, imagen 1 de 2 MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 16, imagen 2 de 2
    • Remove the outer two T6 Torx screws securing both display hinges to the upper case (four screws total).
    Pregunta a FixBot
    Agregar Comentario
  17. MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 17, imagen 1 de 1
    • Open your MacBook Pro so the display is perpendicular to the upper case.
    • Place your opened MacBook Pro on a table as pictured.
    • While holding the display and upper case together with your left hand, remove the remaining T6 Torx screw from the lower display bracket.
    Pregunta a FixBot
    Agregar Comentario
  18. MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 18, imagen 1 de 1
    • Be sure to hold the display and upper case together with your left hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
    • Remove the last remaining T6 Torx screw securing the display to the upper case.
    Pregunta a FixBot
    Agregar Comentario
  19. MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 19, imagen 1 de 3 MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 19, imagen 2 de 3 MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 19, imagen 3 de 3
    • Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
    • Rotate the display slightly away from the upper case.
    • Lift the display up and away from the upper case, minding any brackets or cables that may get caught.
    Pregunta a FixBot
    Agregar Comentario
  20. MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement, Front Display Glass: paso 20, imagen 1 de 2 MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement, Front Display Glass: paso 20, imagen 2 de 2
    • In the following steps, you will use a heat gun to soften the adhesive securing the outer black border around the underside of the front glass panel to the display. The area the adhesive is applied to is shown in red in the second picture.
    • Before starting, be sure to clean the display glass with lint-free cloth moistened with a mild solution; it will make the suction cup adhere better, and will make checking for dust on reassembly easier
    • With the heat gun set to low, start by heating the outer black border near the upper right corner of the glass panel.
    • Always aim the heat gun away from the soft rubber strip around the display glass. Heating the rubber will cause it to melt slightly, turning its finish from matte to glossy. Touching overheated rubber can cause it to permanently deform.
    • Due to the heat applied, it is normal for a layer of condensation to develop on the inside of the glass panel and/or the outside of the LCD. It can be removed with glass cleaner once the glass is separated from the display.
    Pregunta a FixBot
    Agregar Comentario
  21. MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 21, imagen 1 de 3 MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 21, imagen 2 de 3 MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 21, imagen 3 de 3
    Heavy-Duty Suction Cups (Pair)
    $16.95
    • With the panel sufficiently heated, fasten a heavy-duty suction cup near the upper right corner of the display glass.
    • Don't fasten the suction cup on top of the rubber strip around the edge of the display glass.
    • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
    • Slowly and gently pull the corner of the display glass up off the display assembly.
    • If only the top edge of the glass lifts up (as seen in the third picture), repeat steps one and two until you can lift up the corner of the panel.
    Pregunta a FixBot
    Agregar Comentario
  22. MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 22, imagen 1 de 3 MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 22, imagen 2 de 3 MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 22, imagen 3 de 3
    • Gently lift the corner of the display glass enough to insert a spudger between it and the display assembly.
    • Use the flat end of a spudger to gently pry up the adhesive securing the front glass to the display.
    • Pry up the glass panel a few inches away from the upper right corner along the top and right edges of the display.
    Pregunta a FixBot
    Agregar Comentario
  23. MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 23, imagen 1 de 2 MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 23, imagen 2 de 2
    • Use a heat gun to soften the adhesive under the black strip along the right side of the front glass panel.
    • Attach a suction cup along the right side of the front glass panel.
    • Pull up on the glass panel while you use the flat end of a spudger to separate it from the rest of the display assembly.
    • Continue working along the right edge of the front display glass until it is separated from the display.
    • It may be helpful to use a guitar pick or another thin plastic object to keep the upper right corner of the front glass panel from sticking back down to the display assembly.
    Pregunta a FixBot
    Agregar Comentario
  24. MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 24, imagen 1 de 2 MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 24, imagen 2 de 2
    • Use your heat gun to soften the adhesive under the black strip along the top edge of the glass display panel.
    • Attach a suction cup near the top edge of the glass display panel and use it to pull the glass panel up off the display.
    • Work along the top edge of the glass panel, carefully using the flat end of a spudger to separate the adhesive if necessary.
    Pregunta a FixBot
    Agregar Comentario
  25. MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 25, imagen 1 de 2 MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 25, imagen 2 de 2
    • Use a heat gun to soften the adhesive under the black strip near the upper left corner of the glass display panel.
    • Attach a suction cup near the upper left corner of the glass display panel.
    • Pull up on the suction cup and use the flat end of a spudger to carefully pry the glass display panel out of the display assembly.
    • Once the upper left corner has been separated from the display, it may be helpful to use a guitar pick or another thin plastic object to keep the glass from sticking back down to the display assembly.
    Pregunta a FixBot
    Agregar Comentario
  26. MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 26, imagen 1 de 2 MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 26, imagen 2 de 2
    • Use a heat gun to soften the adhesive under the black strip along the left side of the front glass panel.
    • Attach a suction cup along the left side of the front glass panel.
    • Continue working along the left edge of the front display glass until it is separated from the display.
    Pregunta a FixBot
    Agregar Comentario
  27. MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 27, imagen 1 de 2 MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 27, imagen 2 de 2
    • Now that the top, left, and right edges of the glass are free from the display, slowly lift the top edge of the glass panel and gently rotate it out of the display.
    • If necessary, use the flat end of a spudger to free the bottom edge of the glass display panel from the display assembly.
    • Before reassembling, be sure to clean both the inside of the glass display panel and the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is on.
    Pregunta a FixBot
    Agregar Comentario
  28. MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 28, imagen 1 de 2 MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 28, imagen 2 de 2
    • Insert the edge of a plastic opening tool between the display glass and the camera bracket, and run it around the camera bracket to separate it from the display glass.
    • Do not forget to stick the camera bracket down to the new front display glass before reassembly.
    Pregunta a FixBot
    Agregar Comentario
  29. MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 29, imagen 1 de 3 MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 29, imagen 2 de 3 MacBook Pro 15" Unibody Mid 2009 Front Display Glass Replacement: paso 29, imagen 3 de 3
    • During the glass removal process, the camera cable may stick to the adhesive on the glass panel, disconnecting it from the camera board as the panel is lifted. If your camera cable is still connected to the camera board, skip this step.
    • To reconnect the cable, first use the tip of a spudger to remove the piece of foam tape over the camera cable ZIF socket.
    • Use the tip of a spudger to flip up the ZIF cable retainer on the camera cable socket.
    • Insert the camera cable into its socket on the camera board and use the tip of a spudger to snap down the ZIF cable retainer, locking the cable in place.
    • Reapply the piece of tape covering the camera cable socket.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
11 personas más completaron esta guía.
3Guía Comentarios
I just finished doing mine. Removing the whole display panel is massive overkill, it is very easy to replace this glass with the panel mounted on the computer. I think that the whole disassembly process exposes you to far more risk of damaging your computer than the mild inconvenience of having the display panel still attached. The most important thing is to make sure the surfaces are as clean as possible, i have a tiny little fiber that got caught between and I'm cursing myself!
Jonathan - Contestar Compartir
hello to everyone! unfortunately I have to replace the adhesive of the glass panel with a new one, how can I completely remove the old adhesive? once fixed the new one and leaning over the screen, I have to warm it the same? thank you very much
caronte88 - Contestar Compartir
I have followed all the instructions by the book, but now when the computer turns on the screen stays off. I have tried an external display assuming the LCD panel went bad, but it won't work either. Any ideas?
Thanks!
Lucas Martins - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 61
Todo El Tiempo: 24,294
