Introducción
Replacing the microphone requires removal of the logic board.
Partes
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm (14.1 mm) Phillips screws.
Seven 3 mm Phillips screws.
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Remove the three 3.4 mm T6 Torx screws securing the left fan to the logic board.
Use the flat end of a spudger to lift the right fan connector out of its socket on the logic board.
Carefully lift the logic board assembly from its left side and work it out of the upper case, minding the optical drive cable and the I/O ports that may get caught during removal.
If necessary, use the flat end of a spudger to separate the microphone from the upper case.
Pull the I/O port side of the logic board away from the side of the upper case and remove the logic board assembly.
Carefully pull the microphone cables upward to lift the microphone connector out of its socket on the logic board.
3 personas más completaron esta guía.
2 comentarios
Supposed I want to semi-permanently remove microphone functionality altogether at the hardware level, but not necessarily remove it (for the same privacy reasons as disconnecting the built in camera) . Is this the best way to do it, or is there another way that is not so extensive?
