Saltar al contenido principal
MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Lower Case Replacement
Qué necesitas
  1. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Lower Case Replacement, Lower Case: paso 1, imagen 1 de 1
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Lower Case Replacement: paso 2, imagen 1 de 1
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
Conclusión
26 personas más completaron esta guía.
Un comentario
These two little plastic clamps on the upper case that snap on/off the lower case broke. I was looking through the store for replacements but I couldn't find any. Does anyone know where I can get these?
hmalissa - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 15
Todo El Tiempo: 15,691
