Introducción
Use this guide to replace a broken or noisy left fan in your MacBook Pro 15" Retina Display Mid 2015.
Note that the left fan is on the left of the machine while you're using it, and on the right while you're working on it.
Qué necesitas
Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
Eight 3.1 mm
Two 2.3 mm
47 personas más completaron esta guía.
2 comentarios
First repair job. After 5 years of use my laptop was getting heated quicker than the oven and making that antique modem noises. With 2 screwdrivers and a plastic card to pry the connectors cleaned all the dust inside the case and the fans following the fan replacement guides without any trouble. Huge thanks to Andrew for this very detailed page! Btw, if you intent to reuse the fans, be careful with the connector cables. They are not flexible, they bent easily and might break.
