Introducción
Use this guide to upgrade or replace the solid-state drive in a MacBook Pro 15” Mid 2014. This MacBook Pro uses a proprietary storage drive connector, and is therefore not compatible with common M.2 drives without the use of an adapter.
Before you perform this repair, if at all possible, back up your existing SSD. Then, either familiarize yourself with internet recovery or create a bootable external drive so you’ll be ready to install macOS onto your new drive and migrate your data to the new SSD.
Finally, we strongly recommend installing macOS 10.13 High Sierra (or a later macOS) before replacing the original SSD from your MacBook Pro. Most new SSDs require updated storage drivers not found in versions of macOS prior to High Sierra.
Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
Eight 3.0 mm
Two 2.3 mm
95 personas más completaron esta guía.
26 comentarios
I am also wondering the same. Is there a second SSD drive bay?
if i bought the 1TB SSD Im not sure how you clone everything to it before it is installed?
Is it possible to install 1TB SSD? What brand should I buy? Or characteristics? Please help me.
JjCruz -
You can use a program such as Carbon Copy Cloner to 'clone' your drive from one to another.
