Introducción
Use this guide to install an I/O board containing a USB 3.0 port, HDMI port, and SDXC card reader.
Qué necesitas
Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
Eight 3.0 mm
Two 2.3 mm
Using the flat end of a spudger, pry the I/O Board connector straight up out of its socket on the logic board.
In a similar fashion, remove the I/O Board cable connector from its socket on the I/O Board.
Remove the I/O Board cable from the MacBook Pro.
Remove the single 2.9 mm T5 Torx screw securing the AirPort card to the logic board.
Use the point of a spudger to flip up the locking mechanism on the I/O board connector.
Flip the spudger around and use the flat end to slide the I/O cable out of the connector.
29 personas más completaron esta guía.
