Introducción
Did your laptop go for an accidental swim? Logic board fried? Use this guide to install a new logic board in your MacBook Pro 15" Retina Display Early 2013.
Herramientas
Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
Eight 3.0 mm
Two 2.3 mm
Use a spudger or tweezers to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board.
Using the flat end of a spudger, pry the I/O Board connector straight up out of its socket on the logic board. On reassembly, connect this end first as it does not flex.
In a similar fashion, remove the I/O Board connector from its socket on the I/O Board.
Remove the I/O Board cable from the MacBook Pro.
Remove the single 2.9 mm T5 (sometimes T6) Torx screw securing the AirPort card to the logic board.
Use the flat end of a spudger to lift the rubber heat sink cover up off the left fan.
Use the tip of a spudger to flip up the I/O board data cable lock and rotate it toward the battery side of the computer.
Use the flat end of a spudger to slide the I/O board data cable straight out of its socket on the logic board.
Use the flat end of a spudger to pry the headphone jack connector up from its socket on the logic board.
Lifting from the side nearest the battery, rotate the logic board toward the top of the MacBook Pro.
Using the flat end of a spudger, carefully push the MagSafe 2 connector out of its socket on the bottom of the logic board.
Clockwise from top: keyboard, trackpad, battery, right speaker, keyboard backlight, display, microphone, headphone jack, left speaker.
Remove the following eight screws securing the heat sink to the logic board:
Two 2.4 mm T5 screws
Six 3.4 mm T5 screws
Grip both ends of the heat sink and lift it up from the logic board.
Use the tip of a spudger to flip up the metal retaining flap on the HDMI data transfer cable.
Gently pull the HDMI data transfer cable straight out of its socket on the logic board.
29 personas más completaron esta guía.
7 comentarios
Updated recently to High Sierra and now my Logic Board is “broken” per apples Genius Bar. Crashing and restarting unpredictably. Wondering if anyone else has had this problem or if they think replacing the logic board is a potential fix. I’m not new to tearing down or building computers so I’d consider it if I found a good part.
It seems most of the GPU problems in mid 2012/early 2013 15” retina macbook pro models are due to U8900 IC “lead free” soldering.
Some people pointed that resoldering this IC fixed the problem.
https://www.youtube.com/watch?v=upk1QbGi...
(In the comments for above video, he mentioned that original chip is also working fine)
Just did this and found the hardest part was getting the new board in without ‘loosing’ some cables. I did loose one - the backlighting cable but the the time I discovered that I was in no mood to take things back apart to retrieve it. Worked fine when done but am having a bit of intermittent behavior which I think may be related to a previously replaced SSD card. New one on the way for Monday install.
Thanks for a great, detailed tutorial. Very tedious - good test of patience.
