Introducción
Use this guide to replace a broken or noisy left fan in your MacBook Pro 15" Retina Display Early 2013. This is the guide to remove the fan on the left side of the computer when it is open and in use.
Qué necesitas
Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
Eight 3.0 mm
Two 2.3 mm
Use the flat end of a spudger to lift the rubber heat sink cover up off the left fan.
34 personas más completaron esta guía.
2Guía Comentarios
Regarding step 7 my experience was different than the procedure described. My fan ribbon cable was not glued down at all and the cable simply slid out of the socket towards the rear of the computer and the new one slid in.
awesome guide. i skipped steps 3-4. prior to placing the back cover on, i tilted the mac on its side and powered up to see if the fan worked, it did. powered down, screwed the cover back on and good to go. took about 20 minutes.
