Introducción
Input, Output, Sideput. Whatever kind of puting you will be doing, a faulty I/O board cable is going to severely limit the functionality of your MacBook Pro with Retina display. This guide will show you how to replace it.
Qué necesitas
Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
Eight 3.0 mm
Two 2.3 mm
Using the flat end of a spudger, pry the I/O board cable straight up out of its socket on the I/O board.
In a similar fashion, remove the I/O board cable from its socket on the I/O board.
Una persona más ha completado esta guía.
