Saltar al contenido principal
MacBook Pro 15" Retina Display Early 2013 Heat Sink Replacement
Qué necesitas
  1. MacBook Pro 15" Retina Display Early 2013 Heat Sink Replacement, Lower Case: paso 1, imagen 1 de 1
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.0 mm
    • Two 2.3 mm
  2. MacBook Pro 15" Retina Display Early 2013 Heat Sink Replacement: paso 2, imagen 1 de 1
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
    • Set the lower case aside.
  3. MacBook Pro 15" Retina Display Early 2013 Heat Sink Replacement, Battery Connector: paso 3, imagen 1 de 1
    • Peel back the warning label covering the battery connector.
  4. MacBook Pro 15" Retina Display Early 2013 Heat Sink Replacement: paso 4, imagen 1 de 2 MacBook Pro 15" Retina Display Early 2013 Heat Sink Replacement: paso 4, imagen 2 de 2
    • Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
    • Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
  5. MacBook Pro 15" Retina Display Early 2013 Heat Sink Replacement, Heat Sink: paso 5, imagen 1 de 3 MacBook Pro 15" Retina Display Early 2013 Heat Sink Replacement, Heat Sink: paso 5, imagen 2 de 3 MacBook Pro 15" Retina Display Early 2013 Heat Sink Replacement, Heat Sink: paso 5, imagen 3 de 3
    • Insert the flat end of a spudger underneath the rubber heat sink cover on the right fan.
    • Slide the spudger underneath the length of the cover, releasing the adhesive.
    • Lift the cover and rotate it off of the heat sink.
  6. MacBook Pro 15" Retina Display Early 2013 Heat Sink Replacement: paso 6, imagen 1 de 3 MacBook Pro 15" Retina Display Early 2013 Heat Sink Replacement: paso 6, imagen 2 de 3 MacBook Pro 15" Retina Display Early 2013 Heat Sink Replacement: paso 6, imagen 3 de 3
    • In the same manner described above, release the adhesive and flip back the heat sink cover on the left fan.
  7. MacBook Pro 15" Retina Display Early 2013 Heat Sink Replacement: paso 7, imagen 1 de 1
    • Remove the following ten screws securing the heat sink to the logic board:
    • Two 2.4 mm T5 Torx screws
    • Six 3.4 mm T5 Torx screws
    • One 5.2 mm Raised Head T5 Torx screw
    • One 3.5 mm T5 Torx screw
  8. MacBook Pro 15" Retina Display Early 2013 Heat Sink Replacement: paso 8, imagen 1 de 1
    • Grasping the heat sink from one side, lift the heat sink off of the MacBook Pro, pulling it free from the computer.
    • The thermal paste may make it difficult to remove the heat sink. Pull the heat sink off gently but forcefully to avoid damaging any components on the logic board.
    • When installing the new heat sink, do not forget to replace the thermal paste underneath the heat sink. See our Applying Thermal Paste guide for further instructions.
Conclusión
20 personas más completaron esta guía.
Sam Goldheart
Miembro Desde 10/18/12
472,481 Reputación
538 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
Miembros de 121
20,368 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 8
Ultimos 30 días: 31
Todo El Tiempo: 16,325
