Saltar al contenido principal
MacBook Pro 15" Core 2 Duo Models A1226 and A1260 RAM Replacement
Qué necesitas
  1. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 RAM Replacement, Battery: paso 1, imagen 1 de 3 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 RAM Replacement, Battery: paso 1, imagen 2 de 3 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 RAM Replacement, Battery: paso 1, imagen 3 de 3
    • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
  2. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 RAM Replacement, RAM Shield: paso 2, imagen 1 de 2 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 RAM Replacement, RAM Shield: paso 2, imagen 2 de 2
    • Remove the three identical 2mm Phillips screws from the memory door.
    • Lift the memory door up enough to grip it and slide it toward you, pulling it away from the casing.
  3. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 RAM Replacement, RAM: paso 3, imagen 1 de 2 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 RAM Replacement, RAM: paso 3, imagen 2 de 2
    • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Pull the chip directly out from its connector.
    • If there are two RAM chips installed, repeat the above procedure for the second chip.
Conclusión
220 personas más completaron esta guía.
Un comentario
Really easy to install RAM on Macbook Pro 15'' Model A1226!!
I had 2GB of RAM (1GB and 1GB), so when I read this tutorial I decided to buy one ram of 2GB 667Mhz and It is working great (now I've got a total of 3 GB). I'm willing to install up to 6 GB with this same tutorial. Recommended!
cesrafa - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 25
Ultimos 30 días: 115
Todo El Tiempo: 131,754
