Introducción
This detects the internal temperature of your machine for heat management.
Qué necesitas
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
Disconnect the right fan cable from the logic board by placing a spudger beneath the cable and lifting up.
Disconnect the right thermal sensor cable from the logic board by placing a spudger beneath the cable and lifting up.
Una persona más ha completado esta guía.
