Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement
Qué necesitas
  1. MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement, Battery: paso 1, imagen 1 de 1
    • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
    Pregunta a FixBot
    Agregar Comentario
  2. MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement, RAM Shield: paso 2, imagen 1 de 1
    • Remove the three identical Phillips screws from the memory door.
    Pregunta a FixBot
    Agregar Comentario
  3. MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement: paso 3, imagen 1 de 1
    • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
    Pregunta a FixBot
    Agregar Comentario
  4. MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement, Upper Case: paso 4, imagen 1 de 1
    • Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
    Pregunta a FixBot
    Agregar Comentario
  5. MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement: paso 5, imagen 1 de 1
    • Remove the following 6 screws:
    • Two 10 mm T6 Torx screws on either side of the RAM slot.
    • Four 14.5 mm Phillips screws along the hinge.
    Pregunta a FixBot
    Agregar Comentario
  6. MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement: paso 6, imagen 1 de 1
    • Remove the four 3.2 mm Phillips screws on the port side of the computer.
    Pregunta a FixBot
    Agregar Comentario
  7. MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement: paso 7, imagen 1 de 1
    • Rotate the computer 90 degrees and remove the two 3.2 mm Phillips screws from the rear of the computer.
    Pregunta a FixBot
    Agregar Comentario
  8. MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement: paso 8, imagen 1 de 1
    • Rotate the computer 90 degrees again and remove the four 3.2 mm Phillips screws from the side of the computer.
    Pregunta a FixBot
    Agregar Comentario
  9. MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement: paso 9, imagen 1 de 1
    • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
    • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case (there are some hidden plastic clips that need to be clicked off).
    Pregunta a FixBot
    Agregar Comentario
  10. MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement: paso 10, imagen 1 de 1
    • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
    • Remove the upper case.
    Pregunta a FixBot
    Agregar Comentario
  11. MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement, Display Assembly: paso 11, imagen 1 de 1
    • Disconnect the three antenna cables attached to the Airport Extreme card.
    • Apple was kind enough to include a label showing where each color antenna cable plugs in - just make sure to look at this when reconnecting the antenna cables.
    Pregunta a FixBot
    Agregar Comentario
  12. MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement: paso 12, imagen 1 de 1
    • Deroute the Airport antenna cables from their channel in the left speaker.
    Pregunta a FixBot
    Agregar Comentario
  13. MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement: paso 13, imagen 1 de 1
    • Disconnect the iSight cable from the logic board by sliding the cable to the left and out of its connector.
    Pregunta a FixBot
    Agregar Comentario
  14. MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement: paso 14, imagen 1 de 1
    • Disconnect the inverter cable from the logic board by placing a spudger beneath the cable and lifting up.
    Pregunta a FixBot
    Agregar Comentario
  15. MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement: paso 15, imagen 1 de 1
    • Disconnect the display data cable from the logic board by pulling sideways.
    Pregunta a FixBot
    Agregar Comentario
  16. MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement: paso 16, imagen 1 de 1
    • Remove the silver T6 Torx securing the ground loop in the display data cable to the casing.
    Pregunta a FixBot
    Agregar Comentario
  17. MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement: paso 17, imagen 1 de 1
    • Support the display with one hand while removing the following 3 screws:
    • Two 9.5 mm silver T6 Torx screws with threads on only part of the shaft on the inside of the display hinges.
    • One 9.5 mm silver T6 Torx screw with threads on the entire shaft on the outside of the left hinge.
    Pregunta a FixBot
    Agregar Comentario
  18. MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement: paso 18, imagen 1 de 1
    • Grasp the display assembly on both sides and lift it up and out of the computer.
    Pregunta a FixBot
    Agregar Comentario
  19. MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement, Rear Display Bezel: paso 19, imagen 1 de 2 MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement, Rear Display Bezel: paso 19, imagen 2 de 2
    • Remove the two 5 mm Phillips screws from the lower left and right corners of the display (two screws total).
    Pregunta a FixBot
    Agregar Comentario
  20. MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement: paso 20, imagen 1 de 3 MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement: paso 20, imagen 2 de 3 MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement: paso 20, imagen 3 de 3
    • Insert the flat end of a spudger perpendicular to the face of the display between the plastic strip attached to the rear bezel and the front bezel.
    • Do not insert your spudger between the plastic strip and the rear bezel.
    • With the spudger still inserted, rotate it away from the display to separate the front and rear bezels.
    • Work along the left edge of the display until the rear bezel is evenly separated from the front bezel.
    Pregunta a FixBot
    Agregar Comentario
  21. MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement: paso 21, imagen 1 de 3 MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement: paso 21, imagen 2 de 3 MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement: paso 21, imagen 3 de 3
    • Work along the right edge of the display until the rear bezel is evenly separated from the front bezel.
    Pregunta a FixBot
    Agregar Comentario
  22. MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement: paso 22, imagen 1 de 3 MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement: paso 22, imagen 2 de 3 MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement: paso 22, imagen 3 de 3
    • Insert the flat end of a spudger between the front bezel and the plastic strip attached to the rear bezel near the screw holes at the bottom corners of the display.
    • Rotate your spudger toward the rear bezel to separate it from the front bezel.
    • If necessary, enlarge the gap between the lower edge of the rear bezel and the clutch cover until the two components are completely separated.
    Pregunta a FixBot
    Agregar Comentario
  23. MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement: paso 23, imagen 1 de 1
    • Lift the rear bezel by its bottom edge and rotate it away from the display assembly to separate the top edge.
    • Remove the rear display bezel from the display assembly.
    Pregunta a FixBot
    Agregar Comentario
  24. MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement, Display Inverter: paso 24, imagen 1 de 1
    • The display inverter is a very thin and delicate circuit board that is easily broken. Use caution when handling.
    • Carefully lift the inverter board out of the clutch cover.
    Pregunta a FixBot
    Agregar Comentario
  25. MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement: paso 25, imagen 1 de 1
    • Disconnect the LCD backlight from the inverter by pulling its connector away from the inverter board.
    Pregunta a FixBot
    Agregar Comentario
  26. MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement: paso 26, imagen 1 de 1
    • Be cautious to not put any strain on the inverter cable ground loop, as it is a very thin and delicate wire.
    • Disconnect the inverter cable by pulling its connector away from the socket on the inverter.
    Pregunta a FixBot
    Agregar Comentario
  27. MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement, Clutch Assembly: paso 27, imagen 1 de 2 MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement, Clutch Assembly: paso 27, imagen 2 de 2
    • Remove the pieces of yellow kapton tape from the bottom left corner of the display.
    • Peel the three green antenna ground straps off the copper tape along the bottom edge of the LCD.
    • The adhesive connecting these straps to the display is very strong. An edged tool is helpful to separate the adhesive while you peel the straps off.
    • Remove the piece of tape securing the camera cable to the LCD.
    Pregunta a FixBot
    Agregar Comentario
  28. MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement: paso 28, imagen 1 de 2 MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement: paso 28, imagen 2 de 2
    • Remove the pieces of tape covering the display data cable and camera cable connectors.
    • Carefully peel the camera cable off the foam tape along the top edge of the LCD.
    Pregunta a FixBot
    Agregar Comentario
  29. MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement: paso 29, imagen 1 de 2 MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement: paso 29, imagen 2 de 2
    • Gently pull the camera cable away from its socket on the camera board.
    • Pull the display data cable connector away from its socket on the LCD.
    • Pull both cables parallel to the face of the logic board.
    Pregunta a FixBot
    Agregar Comentario
  30. MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement: paso 30, imagen 1 de 2 MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement: paso 30, imagen 2 de 2
    • If you have a Core Duo machine, refer to picture 1 and remove three Phillips screws connecting the clutch assembly to the lower edge of the front display bezel near the display data cable.
    • If you have a Core 2 Duo Model A1211 machine, refer to picture 2 and remove two Phillips screws connecting the clutch assembly to the lower edge of the front display bezel near the display data cable.
    Pregunta a FixBot
    Agregar Comentario
  31. MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement: paso 31, imagen 1 de 1
    • Remove the small Phillips screw from behind the display data cable.
    • Remove the small rectangular steel bracket by sliding it away from the right clutch hinge.
    • If you have a Core 2 Duo Model A1211, there is no steel bracket. Simply remove the screw and continue to the next step.
    Pregunta a FixBot
    Agregar Comentario
  32. MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement: paso 32, imagen 1 de 1
    • Remove three Phillips screws attaching the clutch assembly to the lower edge of the front display bezel.
    • The inverter cable ground loop is a very thin and delicate wire. Work gently.
    Pregunta a FixBot
    Agregar Comentario
  33. MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement: paso 33, imagen 1 de 2 MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement: paso 33, imagen 2 de 2
    • Push the open edge of the clutch cover away from the left clutch hinge to pop it off the clips attaching the two parts.
    • If necessary, repeat this process for the right side of the clutch assembly.
    • Remove the clutch assembly from the front display bezel.
    Pregunta a FixBot
    Agregar Comentario
  34. MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement, Display Data Cable: paso 34, imagen 1 de 1
    • De-route the display data cable from around the right clutch hinge and remove it from the front bezel.
    Pregunta a FixBot
    Agregar Comentario
  35. MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement, Right Clutch Hinge: paso 35, imagen 1 de 1
    • Remove the four T6 Torx screws securing the right clutch hinge to the front display bezel.
    Pregunta a FixBot
    Agregar Comentario
  36. MacBook Pro 15" Core 2 Duo Model A1211 Right Clutch Hinge Replacement: paso 36, imagen 1 de 1
    • Remove the right clutch hinge from the front display bezel.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 34
Todo El Tiempo: 7,168
