Introducción
你可以安装厚度最大为9.5mm的硬盘。
Qué necesitas
要重新组装您的设备,请按照本指南的相反顺序进行操作。
580 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
100%
¡ Leon赵国鑫 nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
20 comentarios
Thank you all very much, this guide is perfect for everyone, no matter your level of expertise, i never opened my mac before and i succesfully replaced my old 120 gb HD with a new 320 gb HD 7.200 RPM :) And worked flawlessly!!
BIG UPS to ifixit, this guide is perfect for everyone!
If your button to open mac is hard to use after you re-assembled the computer, check to see if the proper length screws were reinstalled. I had that problem and I switched the 2 screws. One was a tad longer. The longer one when screwed in, interferred with the button function.
Definitely NOT true for MY Mac. Both screws are absolutely identical. Still I had this issue. :-(
Turned out that if I screw them in real tight the issue will occur. If I turn back the screws about 180 degrees (i. e. if I loosen them) the problem disappears.
