Introducción
Use this guide to replace a broken MagSafe DC-In board.
Partes
Remove the following ten screws:
Three 14.4 mm Phillips #00 screws
Three 3.5 mm Phillips #00 screws
Four 3.5 mm shouldered Phillips #00 screws
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Use the edge of a spudger to gently pry the fan connector up and out of its socket on the logic board.
Use the tip of a spudger to pull the right speaker/subwoofer cable out from under the retaining finger molded into the upper case.
Pull the right speaker/subwoofer cable upward to lift the connector out of its socket on the logic board.
Pull the MagSafe DC-In board cable toward the heat sink to disconnect it from the logic board.
Remove the MagSafe DC-In board.
87 personas más completaron esta guía.
6 Comentarios
After reassembling my macbook pro, the screen goes black. I can hear the sound when turns on but nothing is shown on the screen. How do I know if i broke the cable when I took it out from the connector because it was working fine before openning my mac?
just open it again, check the cable that is connected to your monitor if its connected if not connect if so you probably broke it :/
Hi Can you please share the link from where I can buy this? or the part number of magsafe board?
Macbook pro 13’ mid 2012 (MD101HN/A)
Piece of cake, took an hour or so, but I was being extra careful. The only sticky part were the backlight cable and the keyboard ribbon cable ZIF socket, those two items I found fiddly to get re-inserted properly. Thanks for the tutorial.
