Introducción
Use this guide to replace the entire display assembly.
Partes
Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Use the flat end of a spudger to pry up the subwoofer/right speaker cable connector out of its socket on the logic board.
71 personas más completaron esta guía.
17 comentarios
i did this with a display that was working in order to tighten the mounting bolts and eliminate the wobble in the screen. now when i power up the computer the screen fails to light up and the fan turns on. would this mean a shorted logic board?
I had the same problem , I tried to tighten the hinges after I put everything back my macbook was dead only the fan which works.
Did you find out what was the problem
have you checked that the display data cable (the one in the top right of the logic board) is plugged in all the way, same for the bluetooth/wifi/camera cable (next to the optical drive connector) is also plugged in all the way?
