Introducción
Replace a broken AirPort card to regain Wi-Fi connectivity.
Partes
Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Use the flat end of a spudger to pry the subwoofer/right speaker cable connector up off its socket on the logic board.
Disconnect the camera cable by sliding it horizontally out of its socket.
If you see a small plastic retainer stuck to the logic board that prevents the camera cable from sliding out, peel it up carefully from the logic board. Apply a little heat from a hair dryer or heat gun if necessary to help soften the adhesive holding it in place. Do not attempt to forcibly disconnect the cable with the retainer in place.
If you still have trouble, use the point of a spudger to push at each side of the connector and "walk" it slowly from its socket.
Grab the clutch cover as shown and slide it toward the right side of the display.
Use the tip of a spudger to pry both AirPort antenna connectors out of their sockets on the AirPort board.
Remove the single 3 mm Phillips screw securing the AirPort card to the display nearest the AirPort antenna.
70 personas más completaron esta guía.
14 comentarios
Hi,
I'm sorry if this is a dumb question, but I'm new to the community. Where did you buy (a link would be amazing) the AirPort card for this specific laptop? Thanks.
-josh
you can buy this from violetofficesupplies.co.uk
The Wifi from the macbook is working fine, but the bluetooth stop working a week ago. Tried everything software-related, think it is time to start looking at the hardware itself. Just to confirm, the airport card manages wifi AND bluetooth? Or bluetooth has a separate card/adapter? Thanks!
