Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Archivada
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Archivada
Introducción
This guide has been updated by iFixit staff! Read the new, official guide here.
  1. Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
    • Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
    • Red Seven 3 mm Phillips screws.
    • Orange Three 13.5 mm Phillips screws.
  2. Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
    • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
  3. Remove the following tri-wing screws securing the battery to the upper case:
    • Remove the following tri-wing screws securing the battery to the upper case:
    • Red One 5.5 mm tri-wing screw
    • Orange One 13.5 mm tri-wing screw.
  4. Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
    • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
  5. Lift the battery out of the upper case
    • Lift the battery out of the upper case
  6. Remove the ribbon cable by releasing it from the ZIF connector on the underside of the trackpad and also from the socket that attaches it to the logic board. Remove the ribbon cable by releasing it from the ZIF connector on the underside of the trackpad and also from the socket that attaches it to the logic board.
    • Remove the ribbon cable by releasing it from the ZIF connector on the underside of the trackpad and also from the socket that attaches it to the logic board.
  7. Remove the four 1.2mm #00 Phillips head screws from rear of the trackpad. Remove the four 1.2mm #00 Phillips head screws from rear of the trackpad.
    • Remove the four 1.2mm #00 Phillips head screws from rear of the trackpad.
Conclusión
8 personas más completaron esta guía.
SIMRAN
Miembro Desde 30/10/10
6,333 Reputación
1 Guía escrita
Equipo
Master Techs Miembro de Master Techs
Community
295 Miembros
974 Guías creadas
I had better luck using the #000 Phillips to get the 1.2mm screws out during step 7.
benchampa - Contestar
I accidentally disabled my track pad in the system preferences how do I enable it again when the trackpad wont click?
Nicholas Noriega - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 19,720
