Introducción
The heat sink helps keep the processor cool and happy.
Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Use a spudger to pry the fan connector out of its seat, and straight up off the logic board.
Grab the plastic pull tab secured to the display data cable lock, and rotate it toward the DC-in side of the computer.
Pull the display data cable connector straight away from its socket, towards the DC-in side of the computer.
Remove the four 8.5 mm Phillips screws securing the heat sink to the logic board.
41 personas más completaron esta guía.
10 comentarios
After completing this process and reapplying thermal paste on my CPU and GPU, CPU Core 1 & 2 temperature sensors were not being read. As a result, my fan was not operating and the CPU diode temperature jumped to >100C.
To fix this I had to reset the SMC (System Management Controller). For this model it is done by holding done Shift+Control+Option and pressing the power button while the computer is off.
I have OS X 10.8.5 running. I also replaced my battery at the same time as reapplying thermal paste. No idea if that affected the temperature sensors.
heat issue in left side....
please kindly advise for heat issue
CPU and GPU are exactly on left side. So check if fan is working and change thermal paste
Everything was fine and I did it very carefully. But now I can't boot (I did it with the battery almost empty and it seems to be now - the charge indicator works well and flash to indicate an empty battery) and the macbook didn't charge.
The indicator light on the magsafe charger doesn't glow...
Any idea how I should go with this?
I tried Shift+Crtl+Alt+Power Button to reset SMC. I don't know if ti's the good method but I didn't change anything...
Thanks in advance for your help
I have the same problem, did you fix it?
