Introducción
Use this guide to replace a broken optical drive.
Remove the following ten screws:
Three 14.4 mm Phillips #00 screws
Three 3.5 mm Phillips #00 screws
Four 3.5 mm shouldered Phillips #00 screws
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable connector up from its socket on the logic board.
Pull the optical drive cable away from the optical drive.
Remove the two black Phillips #0 screws securing the small metal mounting bracket. Transfer this bracket to your new optical drive or hard drive enclosure.
37 personas más completaron esta guía.
3 Comentarios
What if you aren't replacing the drive with anything? Do you just leave the airpot assembly laying in there?
Wow thanks.
I finally successfully installed caddy for extra hdd. Thanks ALLAH. and thank you guys.
I actually swapped my internal hdd with an ssd. And put hdd into caddy. And replaced caddy with this dvd drive.
After installing I realized I shouldn’t move my internal hdd to caddy. I could just put ssd into caddy. And make that my startup disk.
Anyways. It was a great experience with removing HDD and DVD Drive.
