Introducción
Are the gobs of OEM thermal paste causing your MacBook Pro to be sluggish while hot? Use this guide to remove your heat sink and apply new thermal paste.
Qué necesitas
Remove the following ten screws:
Three 14.4 mm Phillips #00 screws
Three 3.5 mm Phillips #00 screws
Four 3.5 mm shouldered Phillips #00 screws
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Use the edge of a spudger to gently pry the fan connector up and out of its socket on the logic board.
Use the tip of a spudger to pull the right speaker/subwoofer cable out from under the retaining finger molded into the upper case.
Pull the right speaker/subwoofer cable upward to lift the connector out of its socket on the logic board.
Remove the three 8.4 mm #1 Phillips screws securing the heat sink to the logic board.
58 personas más completaron esta guía.
8Guía Comentarios
Really nice repair guide! There's no way I would have gotten this right without your help, but after following your guide my computer works like a million bucks. I had gotten so used to the fan running full speed all the time I almost didn't notice it anymore, but with the new heat sink the fan runs a low speed once again and the computer is nice and quiet like it was when it was new. Thank you.
hello sir i have done all the steps but my macbook still heating up
Check the radiator, when I first opened mine up it was filled with dust. The radiator has a pipe coming from the CPU and it is right in front of the fan. It has little lines coming from it. I used a vacuum to clean it.
Thanks for the guide!
I had huge problems with heating up .. I even got a “leg hair burns” :)
I followed this instruction, replaced thermal paste (nothing fancy .. just some “normal” paste from local IT store), cleaned out all the dust (especially from fan)
now its running like new … fan rarely kicks in and when it does it cools it down really quickly. Of course running some intense apps (like lightroom, starting up photos app, many open chrome tabs with youtube etc … ) will do a lot of stress on CPU so it will heat up.
In general some slight “heating up” is always there .. Apple prefers to run their laptops warmer than spinning up fans. But after proper cleaning and replacing thermal paste it is much more manageable.
Small tip: those really small ribbon cables can be a pain in the a** to put back in, so i got them close to the connector, put a little sticky tape on them and used that sticky tape to pull on the cable and push it in the slot.
Like show in the last picture (21) on the left upper side there is a square shaped black plastic cover. Should we put the thermal paste there also ? Or we should not touch it? Thanks!
