Saltar al contenido principal
MacBook Pro 13" Unibody Early 2011 Lower Case Replacement
Qué necesitas
  1. MacBook Pro 13" Unibody Early 2011 Lower Case Replacement, Lower Case: paso 1, imagen 1 de 1
    • Remove the following ten screws:
    • Three 14.4 mm Phillips #00 screws
    • Three 3.5 mm Phillips #00 screws
    • Four 3.5 mm shouldered Phillips #00 screws
    • When replacing the small screws, align them perpendicular to the slight curvature of the case (they don't go straight down).
  2. MacBook Pro 13" Unibody Early 2011 Lower Case Replacement: paso 2, imagen 1 de 2 MacBook Pro 13" Unibody Early 2011 Lower Case Replacement: paso 2, imagen 2 de 2
    • Use your fingers to pry the lower case away from the body of the MacBook near the vent.
    • Remove the lower case.
Conclusión
60 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 43
Todo El Tiempo: 35,890
