Saltar al contenido principal
MacBook Pro 13" Retina Display Mid 2014 SSD Replacement
Qué necesitas
  1. MacBook Pro 13" Retina Display Mid 2014 SSD Replacement, Lower Case: paso 1, imagen 1 de 1
    Herramienta utilizada en este paso:
    Magnetic Project Mat
    $19.95
    Comprar
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Mid 2014 SSD Replacement: paso 2, imagen 1 de 1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  3. MacBook Pro 13" Retina Display Mid 2014 SSD Replacement: paso 3, imagen 1 de 2 MacBook Pro 13" Retina Display Mid 2014 SSD Replacement: paso 3, imagen 2 de 2
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  4. MacBook Pro 13" Retina Display Mid 2014 SSD Replacement, Battery Connector: paso 4, imagen 1 de 1
    • If necessary, remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Mid 2014 SSD Replacement: paso 5, imagen 1 de 2 MacBook Pro 13" Retina Display Mid 2014 SSD Replacement: paso 5, imagen 2 de 2
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
  6. MacBook Pro 13" Retina Display Mid 2014 SSD Replacement: paso 6, imagen 1 de 1
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
  7. MacBook Pro 13" Retina Display Mid 2014 SSD Replacement, SSD: paso 7, imagen 1 de 1
    • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
  8. MacBook Pro 13" Retina Display Mid 2014 SSD Replacement: paso 8, imagen 1 de 3 MacBook Pro 13" Retina Display Mid 2014 SSD Replacement: paso 8, imagen 2 de 3 MacBook Pro 13" Retina Display Mid 2014 SSD Replacement: paso 8, imagen 3 de 3
    • Lift the free end of the SSD up slightly and pull the SSD straight out of its socket on the logic board.
    • Only lift the end of the SSD enough to allow you to pull it out—about 1/4".
Conclusión
169 personas más completaron esta guía.
Sam Goldheart
Miembro Desde 10/18/12
465,762 Reputación
538 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
135 Miembros
16,817 Guías creadas
78 comentarios
Hello
Can you confirm that the ssd for the macbook pro mid 2014 really is replaceable?
I hear rumours that the ssd is stuck to the motherbord.
Pieter Baeyens - Contestar
I changed the MacBook Pro 13' Mid 2014 SSD successfully from 120GB to 1000GB. Follow all the steps provided and everything will be fine.
Syafiq Sufi -
I spoke with an apple expert at the genius bar and they said that the SSD is Soldered into the motherboard itself. Which is why I bought another MacBook pro for $1500 after mine had corrupted. Once I was informed you could change it out, I filed a complaint with Apple's Tech Support, which they did nothing about and said that their employees were uninformed.
Joe Wilkie -
Yes, I just replaced my MBP Mid 2014 128GB SSD with 480GB SSD. So, I can confirm it works.
Pasi Kivikangas -
Why is it necessary to disconnect the battery for the SSD replacement?
Robert Kelly - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 44
Ultimos 7 días: 367
Ultimos 30 días: 1,628
Todo El Tiempo: 625,766
