Saltar al contenido principal
MacBook Pro 13" Retina Display Mid 2014 Heat Sink Replacement
Qué necesitas
  1. MacBook Pro 13" Retina Display Mid 2014 Heat Sink Replacement, Lower Case: paso 1, imagen 1 de 1
    Herramienta utilizada en este paso:
    Magnetic Project Mat
    $19.95
    Comprar
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Mid 2014 Heat Sink Replacement: paso 2, imagen 1 de 1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  3. MacBook Pro 13" Retina Display Mid 2014 Heat Sink Replacement: paso 3, imagen 1 de 2 MacBook Pro 13" Retina Display Mid 2014 Heat Sink Replacement: paso 3, imagen 2 de 2
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  4. MacBook Pro 13" Retina Display Mid 2014 Heat Sink Replacement, Battery Connector: paso 4, imagen 1 de 1
    • If necessary, remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Mid 2014 Heat Sink Replacement: paso 5, imagen 1 de 2 MacBook Pro 13" Retina Display Mid 2014 Heat Sink Replacement: paso 5, imagen 2 de 2
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
  6. MacBook Pro 13" Retina Display Mid 2014 Heat Sink Replacement: paso 6, imagen 1 de 1
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
  7. MacBook Pro 13" Retina Display Mid 2014 Heat Sink Replacement, Heat Sink: paso 7, imagen 1 de 3 MacBook Pro 13" Retina Display Mid 2014 Heat Sink Replacement, Heat Sink: paso 7, imagen 2 de 3 MacBook Pro 13" Retina Display Mid 2014 Heat Sink Replacement, Heat Sink: paso 7, imagen 3 de 3
    • Carefully remove the rubber fan bumper from the edge of the heat sink.
    • The fan bumper wraps around the heat sink and fits into slots in the fan duct. During reassembly, be sure to fit the tabs into the notches in the fan duct.
  8. MacBook Pro 13" Retina Display Mid 2014 Heat Sink Replacement: paso 8, imagen 1 de 2 MacBook Pro 13" Retina Display Mid 2014 Heat Sink Replacement: paso 8, imagen 2 de 2
    • Use the flat end of a spudger to peel the four foam stickers off of the heat sink screws.
  9. MacBook Pro 13" Retina Display Mid 2014 Heat Sink Replacement: paso 9, imagen 1 de 1
    • Remove the following screws securing the heat sink to the logic board:
    • Four 2.6 mm T5 screws
    • One 2.4 mm Phillips #000 screw
  10. MacBook Pro 13" Retina Display Mid 2014 Heat Sink Replacement: paso 10, imagen 1 de 2 MacBook Pro 13" Retina Display Mid 2014 Heat Sink Replacement: paso 10, imagen 2 de 2
Conclusión
15 personas más completaron esta guía.
Sam Goldheart
Miembro Desde 10/18/12
465,970 Reputación
538 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
136 Miembros
17,299 Guías creadas
Un comentario
Do I need Anti-Static Wrist Strap ?
if so, where do i connect it, to laptop ?
mikele - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 19
Ultimos 30 días: 103
Todo El Tiempo: 21,117
