Introducción
Use this guide to replace the AirPort card.
Qué necesitas
Herramienta utilizada en este paso:Magnetic Project Mat$19.95
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Wedge the tip of a spudger underneath each of the antenna cables, near their connectors and pry up to disconnect them from the AirPort board.
Connect the long-sleeved cable to the center socket.
The short-sleeved cable connects next to the screw.
The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
16 personas más completaron esta guía.
