Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
Prereq for removing the upper case.
Partes
No se especificaron partes.
  1. Remove the following screws securing the trackpad to the upper case:
    • Remove the following screws securing the trackpad to the upper case:
    • Four 1.4 mm Phillips #000 screws
  2. Wedge the spudger between the trackpad ribbon cable and the upper case. Run the spudger along the bottom to release the trackpad ribbon cable from the adhesive securing it to the upper case.
    • Wedge the spudger between the trackpad ribbon cable and the upper case.
    • Run the spudger along the bottom to release the trackpad ribbon cable from the adhesive securing it to the upper case.
  3. Insert the tip of a spudger in between the trackpad ribbon cable and the upper case. Carefully thread the trackpad ribbon cable out of the notch near the top of the SSD assembly cavity.
    • Insert the tip of a spudger in between the trackpad ribbon cable and the upper case.
    • Carefully thread the trackpad ribbon cable out of the notch near the top of the SSD assembly cavity.
  4. Once the trackpad is free of the upper case, guide the trackpad ribbon cable through the slot cut in the upper case. Remove the trackpad from the upper case.
    • Once the trackpad is free of the upper case, guide the trackpad ribbon cable through the slot cut in the upper case.
    • Remove the trackpad from the upper case.
Conclusión
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 79
