Saltar al contenido principal
MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement
Sólo Prerrequisito
Esta guía solo debería usarse como prerrequisito para otras guías. Por tanto, estará incompleta.
Qué necesitas
  1. MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement, AirPort Board Assembly: paso 1, imagen 1 de 1
    • Remove the single 2.7 mm T5 Torx screw securing the AirPort board to the I/O board.
  2. MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: paso 2, imagen 1 de 3 MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: paso 2, imagen 2 de 3 MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: paso 2, imagen 3 de 3
    • Use the flat end of a spudger to pry and disconnect the three antenna cable connectors from the AirPort board.
    • The three cables are coded with black sleeves of different lengths. During reassembly:
    • Connect the long-sleeved cable to the center socket.
    • The short-sleeved cable connects next to the screw.
    • The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
  3. MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: paso 3, imagen 1 de 2 MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: paso 3, imagen 2 de 2
    • Move the antenna cables aside, clear of the AirPort board.
  4. MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: paso 4, imagen 1 de 2 MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: paso 4, imagen 2 de 2
    • Wedge a plastic opening tool between the AirPort board (side nearest the I/O ports) and the I/O board.
    • Gently pry the AirPort board upwards, but do not remove it.
    • Only lift the AirPort board as much as is necessary to get a grip on it. Lifting it too high above the I/O board may damage the board or the socket.
  5. MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: paso 5, imagen 1 de 2 MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: paso 5, imagen 2 de 2
    • Pull the AirPort board straight out of its socket on the I/O board.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 85
