Introducción
Utiliza esta guía para reemplazar el ventilador.
No olvides seguir nuestra [guía|744|guía de aplicación de pasta térmica] antes de reinstalar tu disipador de calor.
Qué necesitas
Quita los 10 tornillos que aseguran la parte inferior de la carcasa a la parte superior:
Dos tornillos Pentalobe P5 de 2.3 mm
Ocho tornillos Pentalobe P5 de 3.0 mm
Retira con cuidado el tope de goma del ventilador del borde del disipador de calor.
Utiliza la punta de un spudger para empujar a cualquier lado del conector del cable de la cámara para desplazarla afuera de su zócalo en la placa lógica.
Para volver a armar tu dispositivo, sigue estas instrucciones en orden inverso.
82 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
17 comentarios
Very good instructions, just completed the fan replacement, no issues -
Fantastic instructions, brilliant depictions for assistance. Thank you!
I completed this guide and it was brilliant, so thank you Andrew Optimus Goldberg and your contributors! I have a question about the Macbook's heat post-installation of a new fan.
I replaced the fan last night, and put everything back together. Today, the new fan is responding well under activities that would previously make the fan extremely loud and cause intense heat to build up on the bottom right of the Macbook: so far so good.
However, it seems heat is now being distributed to the keys and directly below the screen, and I can even feel it underneath the trackpad, and this is from simply turning the Macbook on with no applications straining the CPU.
Is this something to worry about? Have I possibly made a mistake in my installation, or is this normal for an ordinary working fan?
Thanks for any help that may be given. Appreciated
Is the fan you replaced the original one with the exact same model? While im no expert on this stuff my guess would be that it distributes air differently. I hope it works out for you though.
Nikolay -
Just completed the fan replacement. Great clear instructions. No issues. Thank you so much.
