Introducción
Use this guide to replace the solid state drive tray.
Qué necesitas
Herramienta utilizada en este paso:Magnetic Project Mat$19.95
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Use the flat end of a spudger to pry the SSD cable connector up from its socket on the logic board.
4 personas más completaron esta guía.
