Introducción
Replacing a defective fan is pretty easy and will keep your laptop running cool.
Herramientas
Partes
Resumen del Video
Remove ten Phillips screws securing the lower case to the MacBook Air:
Six 2.8 mm screws
Two 3.8 mm screws
Two 5.4 mm screws
Disconnect the port hatch ribbon cable from the logic board by pulling it straight up by its black pull tab.
Pull the audio out ribbon cable off the adhesive securing it to the upper case.
Use a spudger to pry the audio out ribbon cable connector board off the hard drive bracket.
Use the tip of a spudger to pull the fan cable connector straight away from its connector on the logic board.
Remove the four 2.5 mm Phillips screws securing the fan to the heat sink assembly.
24 personas más completaron esta guía.
2 Comentarios
Can i replace the fan from a 2008 A1237 model with the one from the 2008-2009 A1304?
