Saltar al contenido principal
MacBook Air Models A1237 and A1304 Audio Cable Replacement
Qué necesitas
  1. MacBook Air Models A1237 and A1304 Audio Cable Replacement, Lower Case: paso 1, imagen 1 de 1
    • Unplug your MacBook Air and power it off before you proceed.
    • Remove ten Phillips screws securing the lower case to the MacBook Air:
    • Six 2.8 mm screws
    • Two 3.8 mm screws
    • Two 5.4 mm screws
  2. MacBook Air Models A1237 and A1304 Audio Cable Replacement: paso 2, imagen 1 de 2 MacBook Air Models A1237 and A1304 Audio Cable Replacement: paso 2, imagen 2 de 2
    • Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
  3. MacBook Air Models A1237 and A1304 Audio Cable Replacement, Battery: paso 3, imagen 1 de 1
    • Disconnect the battery connector by pulling it straight out of its socket.
  4. MacBook Air Models A1237 and A1304 Audio Cable Replacement: paso 4, imagen 1 de 1
    • Remove the following nine screws securing the battery to the Air:
    • Four 2.9 mm Phillips.
    • Four 3.8 mm Phillips.
    • One 7.2 mm Phillips.
  5. MacBook Air Models A1237 and A1304 Audio Cable Replacement: paso 5, imagen 1 de 1
    • Lift the battery out of the Air.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
  6. MacBook Air Models A1237 and A1304 Audio Cable Replacement, Speaker: paso 6, imagen 1 de 1
    • Remove the following two screws securing the speaker assembly to the upper case.
    • One 3 mm Phillips.
    • One 5.8 mm Phillips.
  7. MacBook Air Models A1237 and A1304 Audio Cable Replacement: paso 7, imagen 1 de 2 MacBook Air Models A1237 and A1304 Audio Cable Replacement: paso 7, imagen 2 de 2
    • Use a spudger to lift the audio-out connector board off the adhesive that secures it to the hard drive bracket.
    • Disconnect the audio out connector from its socket.
  8. MacBook Air Models A1237 and A1304 Audio Cable Replacement: paso 8, imagen 1 de 2 MacBook Air Models A1237 and A1304 Audio Cable Replacement: paso 8, imagen 2 de 2
    • Rotate the speaker assembly toward the center of the Air.
    • Use a spudger to pry the speaker cable connector up off the audio board.
  9. MacBook Air Models A1237 and A1304 Audio Cable Replacement, Audio Cable: paso 9, imagen 1 de 2 MacBook Air Models A1237 and A1304 Audio Cable Replacement, Audio Cable: paso 9, imagen 2 de 2
    • Disconnect the port hatch ribbon cable from the logic board by pulling it straight up by its black pull tab.
    • If necessary, pull the audio out ribbon cable off the adhesive securing it to the upper case.
  10. MacBook Air Models A1237 and A1304 Audio Cable Replacement: paso 10, imagen 1 de 1
    • Use the pointed end of a spudger to de-route the microphone cable from the hard drive bracket.
  11. MacBook Air Models A1237 and A1304 Audio Cable Replacement: paso 11, imagen 1 de 1
    • Remove the following screws securing the hard drive to the upper case:
    • Two 3.9 mm Phillips screws.
    • One 4.7 mm Phillips screw.
    • This may be a Torx T6 screw.
  12. MacBook Air Models A1237 and A1304 Audio Cable Replacement: paso 12, imagen 1 de 1
    • Use the tip of a spudger to remove the cosmetic screw cover to reveal the last remaining screw securing the hard drive.
  13. MacBook Air Models A1237 and A1304 Audio Cable Replacement: paso 13, imagen 1 de 1
    • Remove the 4.7 mm Phillips screw securing the hard drive to the upper case.
  14. MacBook Air Models A1237 and A1304 Audio Cable Replacement: paso 14, imagen 1 de 2 MacBook Air Models A1237 and A1304 Audio Cable Replacement: paso 14, imagen 2 de 2
    • Lift the hard drive slightly and use a spudger to pry the audio cable connector up off the logic board.
    • Peel the audio cable off the adhesive securing it to the upper case.
Conclusión
94 personas más completaron esta guía.
7 comentarios
Great! it works!
Jorge - Contestar
It's perfect guide. I had a same situaton with my Air and cable that I ordered from here works perfect.
Thanks
William Sawyer - Contestar
I had no audio, with the sound icon in menu bar absent and volume panel grayed out. This repair worked! Be sure to label each screw type from each step of the guide (some screws that were supposed to be same mm from two different steps were not). Be careful not to strip screws when removing them, and not to cross-thread when reinserting. Thanks for the guide.
angbra - Contestar
It works , easy to follow guide and super fast shipping of the cable (just 6days), thanks guys ! BRGDS from Spain
hectorramirezrodriguez - Contestar
I have sound!!! Cable that i ordered here works perfekt for me too. Thank you very much.
michal - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 20
Todo El Tiempo: 56,300
