Introducción
Use this guide to replace the Touch ID sensor in a 2019 MacBook Air.
Note that Touch ID will not function after replacing the Touch ID sensor. The MacBook’s original Touch ID sensor is uniquely paired to the T2 chip on the logic board at the factory—and without Apple’s proprietary calibration process, even a genuine replacement Touch ID sensor from another MacBook Air won’t work.
If you replace the Touch ID sensor, you must install a paired logic board to retain Touch ID functionality.
Qué necesitas
If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
Use a P5 driver to remove the following screws:
Two 7.9 mm screws
Two 7.1 mm screws
Six 2.6 mm screws
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Remove the lower case.
Peel back the tape covering the battery connector enough to reveal the connector underneath.
Slide the tip of a spudger underneath the speaker cable and pry straight up to disconnect the speaker.
Use a T3 Torx driver to remove the three 1.4 mm screws securing the audio board cable bracket.
Remove the cable bracket.
Remove the following screws:
Two 4.3 mm, T5 Torx screws
One 2.4 mm, T3 Torx screw
Use a T3 Torx driver to remove the six 1.6 mm screws securing the Touch ID sensor and its bracket.
Remove the Touch ID bracket.
5 personas más completaron esta guía.
4 comentarios
Hold on so you can replace the touch id but you wont be able to use it? lol kind of redundant if you ask me.
Can you still use the power button with a touch id replacement?
yes, it will power the machine up!
