Introducción
Use this guide to replace your Air's solid state hard drive.
Herramientas
Partes
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
64 personas más completaron esta guía.
12 Comentarios
I understand this is probably a noob question, but can somebody explain what is preventing anybody from swapping a 128GB SSD for a 256GB?
You should be able to transfer the os installer into an 8+ gb thumb drive via DiskMakerX. You do need a working mac with something that works with the mac app store installed and enough space to download the os from the app store. Afterwards, just boot up your mac with the alt key, and install.
diskmakerx.com
Are you certain it's a P5 pentalobe driver? We found the P5 doesn't fit, and have always used a Wiha 267IPR / 4IPR x 40
