Introducción
Use this guide to restore wireless connectivity to your MacBook Air 13" Early 2015 by replacing the Airport/Bluetooth card.
Qué necesitas
Herramienta utilizada en este paso:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card.
16 personas más completaron esta guía.
5 comentarios
Hi! I did this as the bluetooth was not working on my macbook air (after water damage). Once I replaced it, instead of a "bluetooth not available" dialogue, Bluetooth options now do not appear in the System Preferences window, and in the system report, it just says "no information available".
Is this a connection issue, did I get the wrong card, or did the water damage actually destroy the antennae? Wifi works fine both before and after replacing the card.
Hi,
i opened up my Mac and cleaned it after water because it was running slow and the fan was going crazy. IT worked and I hadn’t no notebook issues when I ran apple diagnostics but now I can’t see all my wifi networks or even connect to my phone wireless hotspot And it keeps saying password invalid wen it’s always right!
The wifi shows the same networks like 3 of them but there use to be at least 30 as I live in an apartment block. Is this a airport problem or antenna??
for connecting antenna wires to airport card. You need to hold in place with tweazers then push down with finger or blunt spudger. be careful as you dont want to damage to connector if not placed perfectly in place. ive damaged one before so if it doesnt feel right dont apply to much pressure. reseat and try again
Hi Sam, Evan, all,
I have some difficult technical questions I’d really like to ask I do not need you to condone regarding some BGA/soldering repairs. I’d love to ask you some spec questions. You’re well versed in Apple tech and I a computing-array guy. I would love a message back wherever you’re comfortable. I am building up to the intense process of motherboard creation & design with have no illusions that this is easy (I have done my research). I’m going to desolder the RAM here & it I have plenty of parts to break now so <20% chance is fine. My current project requires honing skills. When I get to the higher echelons/PRICEY equipment I need a proficient competency in this basic stuff as foundation.
Email is ibrad215@gmail.com I doubt you want a public answer on a guide for anyone with Google, but I could really use some help making a few decisions I won’t hold against you if they fail. Call it computer science and not faultless repair, & a chance to learn I will gladly share w/you as research!
