Saltar al contenido principal
MacBook Air 13" Early 2014 Fan Replacement
Qué necesitas
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  1. MacBook Air 13" Early 2014 Fan Replacement: paso 2, imagen 1 de 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  2. MacBook Air 13" Early 2014 Fan Replacement, Battery Connector: paso 3, imagen 1 de 2 MacBook Air 13" Early 2014 Fan Replacement, Battery Connector: paso 3, imagen 2 de 2
    • To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery.
    • Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
    • Do not lift upward on the connector as you disconnect it or you risk damage to the connector socket.
  3. MacBook Air 13" Early 2014 Fan Replacement, I/O Board Cable: paso 4, imagen 1 de 1
    • Use the flat end of a spudger to pry the I/O board cable connector up out of its socket on the I/O board.
  4. MacBook Air 13" Early 2014 Fan Replacement: paso 5, imagen 1 de 1
    • Carefully peel the I/O board cable from the adhesive securing it to the top of the fan.
    • During reassembly, make sure this cable is in the correct orientation. It will fit if reversed, but the laptop will not boot.
  5. MacBook Air 13" Early 2014 Fan Replacement: paso 6, imagen 1 de 2 MacBook Air 13" Early 2014 Fan Replacement: paso 6, imagen 2 de 2
    • The following connector has an especially deep socket. Use care when disconnecting it.
    • While gently pulling the I/O board cable upward near its connection to the logic board, use the flat end of a spudger to pry up on alternating sides of the connector to help "walk" it out of its socket.
    • Remove the I/O board cable.
  6. MacBook Air 13" Early 2014 Fan Replacement, Fan: paso 7, imagen 1 de 1
    • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  7. MacBook Air 13" Early 2014 Fan Replacement: paso 8, imagen 1 de 1
    • Peel the rubber gasket off the adhesive on the top of the fan.
  8. MacBook Air 13" Early 2014 Fan Replacement: paso 9, imagen 1 de 1
    • Remove the following three screws securing the fan to the upper case:
    • One 5.4 mm T5 Torx screw
    • One 3.3 mm T5 Torx screw
    • One 4.6 mm T5 Torx screw with a short head
  9. MacBook Air 13" Early 2014 Fan Replacement: paso 10, imagen 1 de 2 MacBook Air 13" Early 2014 Fan Replacement: paso 10, imagen 2 de 2
    • Lift the fan from the I/O board side and pull it free from the upper case.
    • Removing the fan will also disconnect the fan ribbon cable. Be careful not to snag it.
    • If you feel resistance as you remove the fan, carefully disconnect its cable using a pair of tweezers.
Conclusión
25 personas más completaron esta guía.
Sam Goldheart
Miembro Desde 10/18/12
457,252 Reputación
537 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
137 Miembros
17,047 Guías creadas
2 comentarios
You’re using the wrong model macbook air here, the 2014 has a different battery connector that YOU SHOULD NOT lift up.
Nick katz - Contestar
I think you’re using a different model of a macbook air because the 2014 model has a different battery connector that you shouldn’t lift up bcs you can broke it
Damian Mil - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 28
Ultimos 30 días: 113
Todo El Tiempo: 19,341
