Saltar al contenido principal
MacBook Air 11" Mid 2012 Solid-State Drive Replacement
Qué necesitas
  1. MacBook Air 11" Mid 2012 Solid-State Drive Replacement, Lower Case: paso 1, imagen 1 de 1
    Herramienta utilizada en este paso:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Comprar
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Mid 2012 Solid-State Drive Replacement: paso 2, imagen 1 de 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 11" Mid 2012 Solid-State Drive Replacement, Battery: paso 3, imagen 1 de 2 MacBook Air 11" Mid 2012 Solid-State Drive Replacement, Battery: paso 3, imagen 2 de 2
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
  4. MacBook Air 11" Mid 2012 Solid-State Drive Replacement, Solid-State Drive: paso 4, imagen 1 de 1
    • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
  5. MacBook Air 11" Mid 2012 Solid-State Drive Replacement: paso 5, imagen 1 de 2 MacBook Air 11" Mid 2012 Solid-State Drive Replacement: paso 5, imagen 2 de 2
    • Use a spudger to help lift the free end of the SSD just enough to grab it with your other hand.
    • Do not lift the end of the SSD excessively.
    • Pull the drive straight out of its socket and remove it from the logic board.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
Conclusión
51 personas más completaron esta guía.
Equipo
iFixit Miembro de iFixit
Staff
135 Miembros
16,816 Guías creadas
3 comentarios
Excellent instructions. Very easy to do. I used this screwdriver to remove the screws from the bottom of the case: https://www.amazon.com/gp/product/B00N1R...
and I used the Pentalobe-6 from this set to remove the screw holding in the OEM SSD:
https://www.amazon.com/gp/product/B01FE2...
After removing the stock drive, I installed a Samsung M.2 EVO 850 512Gb drive. It is working quite well. I used this adapter so that the M.2 drive fit in my 2012 Macbook Air:
https://www.amazon.com/gp/product/B01NH2...
feinberj - Contestar
How do we reinstall MacOS?
Philippe Morin - Contestar
I am 10 years old I fixed the mac I did this even the Geek squad couldn’t do it and now it works! without your guide.
admin free - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 72
Ultimos 30 días: 285
Todo El Tiempo: 81,780
