Saltar al contenido principal
MacBook Air 11" Mid 2011 Lower Case Replacement
Qué necesitas
  1. MacBook Air 11" Mid 2011 Lower Case Replacement, Lower Case: paso 1, imagen 1 de 1
    Herramienta utilizada en este paso:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Comprar
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Mid 2011 Lower Case Replacement: paso 2, imagen 1 de 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Conclusión
10 personas más completaron esta guía.
Un comentario
Super easy guide. Parts quality may vary depending on dents or other aesthetics. I recommend buying plastic feet just in case you need them and as a backup to existing inventory.
Al N - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 26
Ultimos 30 días: 76
Todo El Tiempo: 13,238
