Saltar al contenido principal
Introducción
Internal prerequisite.
Partes
No se especificaron partes.
  1. MacBook Air 11" Mid 2011 Logic Board Replacement, Logic Board: paso 1, imagen 1 de 2 MacBook Air 11" Mid 2011 Logic Board Replacement, Logic Board: paso 1, imagen 2 de 2
    • Use the flat end of a spudger to free the adhesive loop securing the I/O board power cable to the upper case.
    • Disconnect the I/O board by pulling the power cable away from its socket on the logic board.
    • Pull the cable parallel to the face of the logic board toward the front edge of the Air.
  2. MacBook Air 11" Mid 2011 Logic Board Replacement: paso 2, imagen 1 de 2 MacBook Air 11" Mid 2011 Logic Board Replacement: paso 2, imagen 2 de 2
    • Use the tip of a spudger to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Pull the keyboard backlight ribbon cable out of its socket.
  3. MacBook Air 11" Mid 2011 Logic Board Replacement: paso 3, imagen 1 de 2 MacBook Air 11" Mid 2011 Logic Board Replacement: paso 3, imagen 2 de 2
    • Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
    • Pull the trackpad ribbon cable straight out of its socket toward the front edge of the Air.
  4. MacBook Air 11" Mid 2011 Logic Board Replacement: paso 4, imagen 1 de 1
    • Use the tip of a spudger to de-route the right speaker cable from the slot cut into the logic board.
  5. MacBook Air 11" Mid 2011 Logic Board Replacement: paso 5, imagen 1 de 1
    • Use the flat end of a spudger to pry the right speaker cable connector up and out of its socket on the logic board.
    • Pry up from beneath the cables.
  6. MacBook Air 11" Mid 2011 Logic Board Replacement: paso 6, imagen 1 de 3 MacBook Air 11" Mid 2011 Logic Board Replacement: paso 6, imagen 2 de 3 MacBook Air 11" Mid 2011 Logic Board Replacement: paso 6, imagen 3 de 3
    • Gently push the tip of a spudger under the black plastic flap stuck to the display data cable lock to make the lock pop upward and away from the socket.
    • Remove the small rubber gasket from the corner of the upper case near the display data cable.
  7. MacBook Air 11" Mid 2011 Logic Board Replacement: paso 7, imagen 1 de 1
    • While holding the lock away from the socket, gently pull the display data cable out of its socket.
    • Do not pull upward on the display data cable as you disconnect it, as its socket may break off the logic board.
  8. MacBook Air 11" Mid 2011 Logic Board Replacement: paso 8, imagen 1 de 2 MacBook Air 11" Mid 2011 Logic Board Replacement: paso 8, imagen 2 de 2
    • Use the flat end of a spudger to pry both antenna cable connectors up and off their sockets on the AirPort/Bluetooth card.
  9. MacBook Air 11" Mid 2011 Logic Board Replacement: paso 9, imagen 1 de 1
    • Gently de-route the antenna cables from the slot cut into the logic board.
  10. MacBook Air 11" Mid 2011 Logic Board Replacement: paso 10, imagen 1 de 1
    • Remove the three 3.6 mm T5 Torx screws securing the logic board to the upper case.
  11. MacBook Air 11" Mid 2011 Logic Board Replacement: paso 11, imagen 1 de 1
    • Gently lift the logic board assembly out of the upper case, minding the fragile heat sink and any cables that may get caught.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 1,067
