Saltar al contenido principal
MacBook Air 11" Early 2015 I/O Board Replacement
Qué necesitas
  1. MacBook Air 11" Early 2015 I/O Board Replacement, Lower Case: paso 1, imagen 1 de 1
    Herramienta utilizada en este paso:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Early 2015 I/O Board Replacement: paso 2, imagen 1 de 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 11" Early 2015 I/O Board Replacement, Battery Connector: paso 3, imagen 1 de 2 MacBook Air 11" Early 2015 I/O Board Replacement, Battery Connector: paso 3, imagen 2 de 2
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
  4. MacBook Air 11" Early 2015 I/O Board Replacement, I/O Board Cable: paso 4, imagen 1 de 2 MacBook Air 11" Early 2015 I/O Board Replacement, I/O Board Cable: paso 4, imagen 2 de 2
    • Use the flat end of a spudger to pry the left and right I/O board cable connectors up off their respective sockets on the I/O board.
  5. MacBook Air 11" Early 2015 I/O Board Replacement: paso 5, imagen 1 de 1
    • Lift and remove the I/O board cable.
  6. MacBook Air 11" Early 2015 I/O Board Replacement, Fan: paso 6, imagen 1 de 2 MacBook Air 11" Early 2015 I/O Board Replacement, Fan: paso 6, imagen 2 de 2
    • Use the tip of a spudger to carefully push on each side of the iSight camera cable connector to loosen it out of its socket on the logic board.
    • We recommend you gently "walk" the connector out of its socket.
  7. MacBook Air 11" Early 2015 I/O Board Replacement: paso 7, imagen 1 de 2 MacBook Air 11" Early 2015 I/O Board Replacement: paso 7, imagen 2 de 2
    • Peel the iSight camera cable up off the adhesive securing it to the fan.
  8. MacBook Air 11" Early 2015 I/O Board Replacement: paso 8, imagen 1 de 2 MacBook Air 11" Early 2015 I/O Board Replacement: paso 8, imagen 2 de 2
    • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  9. MacBook Air 11" Early 2015 I/O Board Replacement: paso 9, imagen 1 de 1
    • Remove the following three screws securing the fan to the upper case:
    • Two 5.5 mm T5 Torx screws
    • One 4.6 mm T5 Torx screw
    • In some models this is a 3.6 mm T5 Torx screw.
  10. MacBook Air 11" Early 2015 I/O Board Replacement: paso 10, imagen 1 de 3 MacBook Air 11" Early 2015 I/O Board Replacement: paso 10, imagen 2 de 3 MacBook Air 11" Early 2015 I/O Board Replacement: paso 10, imagen 3 de 3
    • Lift, but do not remove the fan out of its recess in the upper case.
    • Carefully pull the fan ribbon cable out of its socket as you remove the fan from the Air.
  11. MacBook Air 11" Early 2015 I/O Board Replacement, Battery: paso 11, imagen 1 de 1
    • Remove the following five screws securing the battery to the upper case:
    • Two 5.2 mm T5 Torx screws
    • One 6 mm T5 Torx screw
    • Two 2.6 mm T5 Torx screws
  12. MacBook Air 11" Early 2015 I/O Board Replacement: paso 12, imagen 1 de 1
    • When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
  13. MacBook Air 11" Early 2015 I/O Board Replacement, I/O Board: paso 13, imagen 1 de 2 MacBook Air 11" Early 2015 I/O Board Replacement, I/O Board: paso 13, imagen 2 de 2
    • Disconnect the I/O board power cable from the logic board by pulling the cable out of its socket on the logic board.
    • Pull the cable parallel to the face of the logic board toward the front edge of the Air.
  14. MacBook Air 11" Early 2015 I/O Board Replacement: paso 14, imagen 1 de 2 MacBook Air 11" Early 2015 I/O Board Replacement: paso 14, imagen 2 de 2
    • If necessary, use tweezers to remove any tape covering the microphone cable ZIF connector.
  15. MacBook Air 11" Early 2015 I/O Board Replacement: paso 15, imagen 1 de 3 MacBook Air 11" Early 2015 I/O Board Replacement: paso 15, imagen 2 de 3 MacBook Air 11" Early 2015 I/O Board Replacement: paso 15, imagen 3 de 3
    • Use the tip of a spudger to carefully flip up the retaining flap on the microphone cable ZIF socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the microphone ribbon cable straight out of its socket.
  16. MacBook Air 11" Early 2015 I/O Board Replacement: paso 16, imagen 1 de 2 MacBook Air 11" Early 2015 I/O Board Replacement: paso 16, imagen 2 de 2
    • Use the tip of a spudger to pry under the speaker cable near the connector to lift the connector straight up out of its socket.
  17. MacBook Air 11" Early 2015 I/O Board Replacement: paso 17, imagen 1 de 2 MacBook Air 11" Early 2015 I/O Board Replacement: paso 17, imagen 2 de 2
    • De-route the cable from its notch in the I/O board.
  18. MacBook Air 11" Early 2015 I/O Board Replacement: paso 18, imagen 1 de 2 MacBook Air 11" Early 2015 I/O Board Replacement: paso 18, imagen 2 de 2
    • Remove the small rubber gasket from the corner of the upper case nearest the I/O board.
  19. MacBook Air 11" Early 2015 I/O Board Replacement: paso 19, imagen 1 de 1
    • Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
    • In some models this is a 3.1 mm T5 Torx screw.
  20. MacBook Air 11" Early 2015 I/O Board Replacement: paso 20, imagen 1 de 3 MacBook Air 11" Early 2015 I/O Board Replacement: paso 20, imagen 2 de 3 MacBook Air 11" Early 2015 I/O Board Replacement: paso 20, imagen 3 de 3
    • Carefully lift the I/O board by its power cable and pull it away from the edge of the case.
Conclusión
11 personas más completaron esta guía.
Sam Goldheart
Miembro Desde 10/18/12
471,438 Reputación
538 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
118 Miembros
19,410 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 18
Ultimos 30 días: 40
Todo El Tiempo: 7,045
