Saltar al contenido principal
MacBook Air 11" Early 2014 I/O Board Replacement
Qué necesitas
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  1. MacBook Air 11" Early 2014 I/O Board Replacement: paso 2, imagen 1 de 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  2. MacBook Air 11" Early 2014 I/O Board Replacement, Battery Connector: paso 3, imagen 1 de 2 MacBook Air 11" Early 2014 I/O Board Replacement, Battery Connector: paso 3, imagen 2 de 2
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
  3. MacBook Air 11" Early 2014 I/O Board Replacement, I/O Board Cable: paso 4, imagen 1 de 2 MacBook Air 11" Early 2014 I/O Board Replacement, I/O Board Cable: paso 4, imagen 2 de 2
    • Use the flat end of a spudger to pry the left and right I/O board cable connectors up off their respective sockets on the I/O board.
  4. MacBook Air 11" Early 2014 I/O Board Replacement: paso 5, imagen 1 de 1
    • Lift and remove the I/O board cable.
  5. MacBook Air 11" Early 2014 I/O Board Replacement, Fan: paso 6, imagen 1 de 2 MacBook Air 11" Early 2014 I/O Board Replacement, Fan: paso 6, imagen 2 de 2
    • Use the tip of a spudger to carefully push on each side of the iSight camera cable connector to loosen it out of its socket on the logic board.
    • We recommend you gently "walk" the connector out of its socket.
  6. MacBook Air 11" Early 2014 I/O Board Replacement: paso 7, imagen 1 de 2 MacBook Air 11" Early 2014 I/O Board Replacement: paso 7, imagen 2 de 2
    • Peel the iSight camera cable up off the adhesive securing it to the fan.
  7. MacBook Air 11" Early 2014 I/O Board Replacement: paso 8, imagen 1 de 2 MacBook Air 11" Early 2014 I/O Board Replacement: paso 8, imagen 2 de 2
    • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  8. MacBook Air 11" Early 2014 I/O Board Replacement: paso 9, imagen 1 de 1
    • Remove the following three screws securing the fan to the upper case:
    • Two 5.5 mm T5 Torx screws
    • One 4.6 mm T5 Torx screw
    • In some models this is a 3.6 mm T5 Torx screw.
  9. MacBook Air 11" Early 2014 I/O Board Replacement: paso 10, imagen 1 de 3 MacBook Air 11" Early 2014 I/O Board Replacement: paso 10, imagen 2 de 3 MacBook Air 11" Early 2014 I/O Board Replacement: paso 10, imagen 3 de 3
    • Lift, but do not remove the fan out of its recess in the upper case.
    • Carefully pull the fan ribbon cable out of its socket as you remove the fan from the Air.
  10. MacBook Air 11" Early 2014 I/O Board Replacement, Battery: paso 11, imagen 1 de 1
    • Remove the following five screws securing the battery to the upper case:
    • Two 5.2 mm T5 Torx screws
    • One 6 mm T5 Torx screw
    • Two 2.6 mm T5 Torx screws
  11. MacBook Air 11" Early 2014 I/O Board Replacement: paso 12, imagen 1 de 1
    • When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
  12. MacBook Air 11" Early 2014 I/O Board Replacement, I/O Board: paso 13, imagen 1 de 2 MacBook Air 11" Early 2014 I/O Board Replacement, I/O Board: paso 13, imagen 2 de 2
    • Disconnect the I/O board power cable from the logic board by pulling the cable out of its socket on the logic board.
    • Pull the cable parallel to the face of the logic board toward the front edge of the Air.
  13. MacBook Air 11" Early 2014 I/O Board Replacement: paso 14, imagen 1 de 2 MacBook Air 11" Early 2014 I/O Board Replacement: paso 14, imagen 2 de 2
    • If necessary, use tweezers to remove any tape covering the microphone cable ZIF connector.
  14. MacBook Air 11" Early 2014 I/O Board Replacement: paso 15, imagen 1 de 3 MacBook Air 11" Early 2014 I/O Board Replacement: paso 15, imagen 2 de 3 MacBook Air 11" Early 2014 I/O Board Replacement: paso 15, imagen 3 de 3
    • Use the tip of a spudger to carefully flip up the retaining flap on the microphone cable ZIF socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the microphone ribbon cable straight out of its socket.
  15. MacBook Air 11" Early 2014 I/O Board Replacement: paso 16, imagen 1 de 2 MacBook Air 11" Early 2014 I/O Board Replacement: paso 16, imagen 2 de 2
    • Use the tip of a spudger to pry under the speaker cable near the connector to lift the connector straight up out of its socket.
  16. MacBook Air 11" Early 2014 I/O Board Replacement: paso 17, imagen 1 de 2 MacBook Air 11" Early 2014 I/O Board Replacement: paso 17, imagen 2 de 2
    • De-route the cable from its notch in the I/O board.
  17. MacBook Air 11" Early 2014 I/O Board Replacement: paso 18, imagen 1 de 2 MacBook Air 11" Early 2014 I/O Board Replacement: paso 18, imagen 2 de 2
    • Remove the small rubber gasket from the corner of the upper case nearest the I/O board.
  18. MacBook Air 11" Early 2014 I/O Board Replacement: paso 19, imagen 1 de 1
    • Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
    • In some models this is a 3.1 mm T5 Torx screw.
  19. MacBook Air 11" Early 2014 I/O Board Replacement: paso 20, imagen 1 de 3 MacBook Air 11" Early 2014 I/O Board Replacement: paso 20, imagen 2 de 3 MacBook Air 11" Early 2014 I/O Board Replacement: paso 20, imagen 3 de 3
    • Carefully lift the I/O board by its power cable and pull it away from the edge of the case.
Conclusión
11 personas más completaron esta guía.
Sam Goldheart
Miembro Desde 10/18/12
463,313 Reputación
538 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
140 Miembros
15,195 Guías creadas
Un comentario
Does the IO board on this model contain the hall effect sensor(lid sensor)? Where is it located and what does it look like?
Marik - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 18
Ultimos 30 días: 62
Todo El Tiempo: 6,668
