Introducción
Replace your interconnect board to fix a broken hard drive/optical drive connector.
Qué necesitas
Power down your Mac mini, disconnect all of the cables, and flip it over.
Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
The Jimmy should reach a stop about 3/8" down.
We will first remove the AirPort antenna, located in the lower left corner of this picture.
Use the flat end of a spudger to pry the audio ribbon cable connector up off the interconnect board.
5 personas más completaron esta guía.
