Introducción
Remove the top housing to access your mini's internals.
Herramientas
Partes
No se especificaron partes.
Power down your Mac mini, disconnect all of the cables, and flip it over.
Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
The Jimmy should reach a stop about 3/8" down.
45 personas más completaron esta guía.
2 comentarios
Does this work to remove a disc
That's part of the process. After that, you will probably need to disassemble the optical drive.
Donut -
