Introducción
This guide will show you how to replace the logic board.
Partes
No se especificaron partes.
Power down your Mac mini, disconnect all of the cables, and flip it over.
Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
The Jimmy should reach a stop about 3/8" down.
Slightly squeeze the two retaining arms toward each other and lift the AirPort antenna off its post.
Firmly grasp the power button cable connector with a pair of tweezers and lift it straight up off the logic board.
Push the PRAM battery toward the center of the logic board and pull it up out of its holder. You'll have to push the battery in further than you'd expect in order to get it to pop free.
When inserting the new battery, make sure the side with writing along the edges faces the black plastic holder. You should also ensure that the metal connectors make contact with the battery (you can bend them forward if they do not).
24 personas más completaron esta guía.
