Introducción
Replace a faulty AirPort antenna to regain wireless internet connectivity.
Qué necesitas
Power down your Mac mini, disconnect all of the cables, and flip it over.
Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
The Jimmy should reach a stop about 3/8" down.
Slightly squeeze the two retaining arms toward each other and lift the AirPort antenna off its post.
Use the flat end of a spudger to pry the AirPort antenna cable connector up off the AirPort card.
40 personas más completaron esta guía.
